PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Feb 26, 2015 at 2:14 PM
    #1541
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    This ^^^ Looks clean and is much less headache.
  2. Feb 26, 2015 at 2:40 PM
    #1542
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Do you have to remove the strips to punch the holes or not?
    I know it's been mentioned more than a couple times, any discounts or group buys coming up?
  3. Feb 26, 2015 at 2:53 PM
    #1543
    zscott
    Zach
    Utah
    I wouldn't try to punch holes while the weather strips are on the truck if that is what you are meaning. The stand-offs need to be seated on the roof of the truck though that means that you either cut the weather strips into sections, punch holes through them, or leave them off.
    I don't have any plans for sales right now. A group buy is always a possibility if people are interested but nobody has really wanted to try and rally a group together. If someone does I can put pricing and timeline together for such a group.
  4. Feb 26, 2015 at 3:01 PM
    #1544
    NC15TRD
    Nick
    PA
    I'll PM you
  5. Feb 26, 2015 at 3:19 PM
    #1545
    NC15TRD
    Nick
    PA
  6. Feb 26, 2015 at 5:40 PM
    #1546
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'm kinda dense so I'm just gonna ask
    How many crossbars come with the standard DC cab rack and how many is the maximum ?
  7. Feb 26, 2015 at 5:44 PM
    #1547
    NC15TRD
    Nick
    PA
    6 bars +1 to mount the fairing and lights. I think the max is 12 but I'll let someone who knows answer for sure
  8. Feb 26, 2015 at 5:46 PM
    #1548
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I got 6+1 with mine too but I got the upgraded crossbars. I think you could fit a lot more than 12. I don't know why you would need too though.
  9. Feb 26, 2015 at 5:48 PM
    #1549
    OZ-T
    Peter North
    British Columbia
    I should clarify , I would get the HD bars if that matters as to how many will fit
  10. Feb 26, 2015 at 5:51 PM
    #1550
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    What do you want so many bars for? You could add a ton and make it a flat platform if you really wanted to...
  11. Feb 26, 2015 at 5:53 PM
    #1551
    OZ-T
    Peter North
    British Columbia
    I'm just asking how many bars the system can accomodate
  12. Feb 26, 2015 at 6:07 PM
    #1552
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    You get six bars when you order the HD bars. There are holes in the side rail for the HD bars and they're evenly spaced. There are slots in between the set locations that can also accommodate bars. I'd venture to guess you could fit 16HD bars across the top.
  13. Feb 26, 2015 at 6:14 PM
    #1553
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    I just looked at my rack and I'm sure I could fit 21 HD bars across the top. 3 in each of the slots plus the regular locations.
  14. Feb 26, 2015 at 7:03 PM
    #1554
    zscott
    Zach
    Utah
    This if you arrange it this way the rack will be maxed out to its potential with the 1x2" crossbars and have 1/2" between crossbars with 21 total.
  15. Feb 26, 2015 at 7:10 PM
    #1555
    ThomasMore66
    Dallas/Fort Worth & Durango
    And you need this many why?
  16. Feb 26, 2015 at 7:31 PM
    #1556
    zscott
    Zach
    Utah
    Each extra crossbar adds HP. :burnrubber:
    In all honesty the HD crossbars are pretty rigid. With the standard 6 HD bars the only thing you will gain by adding more is the ability to carry smaller items without them falling through the cracks, at which point a solution like Door Ding used becomes lighter weight for the same function.
    OZ, I am assuming you are wanting more load capacity for construction materials?
  17. Feb 26, 2015 at 7:33 PM
    #1557
    OZ-T
    Peter North
    British Columbia
    What's the spacing in between the HD bars if you go with the standard 6 ?
  18. Feb 26, 2015 at 7:34 PM
    #1558
    zscott
    Zach
    Utah
    10" on center, 8" gap.
    next step would be 11 crossbars for 5" on center spacing 3" gap
  19. Feb 26, 2015 at 7:37 PM
    #1559
    OZ-T
    Peter North
    British Columbia
    That's the info I was looking for
    Thanks
  20. Feb 27, 2015 at 3:20 AM
    #1560
    ThomasMore66
    I've asked this before, but I can't seem to find the response in this thread: how much taller is your truck with the rack? I have to park in a parking garage at work every day, and I have one low spot that concerns me.
