PrInSu Design Studio Roof Racks BS Thread
Discussion in 'PrInSu Design Studio' started by zscott, Feb 26, 2014.
  1. Mar 4, 2015 at 12:19 PM
    #1601
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    OZ, in lieu of blocking up the rack, why not add to the top of the rack. I made a couple small cross bars to slide steel over so I wouldn't mar the rails. These could easily be made to go clear across the rack.
  2. Mar 4, 2015 at 12:21 PM
    #1602
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    i wonder if he would make one for a 4runner?
  3. Mar 4, 2015 at 12:22 PM
    #1603
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I think that would take away from the functionality of the T slots in the crossbars
    I'm considering whether I could lower the cap rack somehow
  4. Mar 4, 2015 at 12:45 PM
    #1604
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Maybe they make lower feet? :notsure:
  5. Mar 4, 2015 at 12:49 PM
    #1605
    OZ-T
    Peter North
    British Columbia
    No
    and that rack was discontinued a couple years ago
  6. Mar 4, 2015 at 12:50 PM
    #1606
    NC15TRD
    Nick
    PA
    TOPRAC=problem solved
  7. Mar 4, 2015 at 12:50 PM
    #1607
    zscott
    zscott [OP] Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    If you want I can build you a custom one that the side plates are taller on so the crossbars would be taller but not the standoffs. No sense in going through too much hassle when I can get you a clean strong solution. I just would need some extra lead time from you to get it cut.
  8. Mar 4, 2015 at 12:55 PM
    #1608
    OZ-T
    Peter North
    British Columbia
    I'll consider that , thanks man
  9. Mar 4, 2015 at 12:56 PM
    #1609
    Bman4X5
    Bman4X5 There is no substitute for square inches.
    Bruce
    Upland CA
    '15 AC/OR
    Bilstein, Dakar/Icon, Prinsu, CBI, Pelfreybilt, Tepui
    Why buy from anyone else with personal service like this? Just sayin'...
  10. Mar 4, 2015 at 12:56 PM
    #1610
    OZ-T
    Peter North
    British Columbia
    would be a custom mount to do a toprac to my existing rack feet too , problem remains
  11. Mar 5, 2015 at 9:07 AM
    #1611
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
  12. Mar 5, 2015 at 9:50 AM
    #1612
    OneFastGeek
    2010 TRD Sport 4x4
  13. Mar 5, 2015 at 11:29 AM
    #1613
    zscott
    Zach
    Utah
  14. Mar 5, 2015 at 11:38 AM
    #1614
    SMKYTXN
    Nathan
    Houston
    DCFB
    The HD rails have slots on the bottom.
  15. Mar 5, 2015 at 11:40 AM
    #1615
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    X
  16. Mar 5, 2015 at 1:00 PM
    #1616
    zscott
    Zach
    Utah
    HD crossbars do, standard don't. Although there isn't much space under the rack for items. Only about an inch at the tightest point which limits the type of table you put under there.
  17. Mar 5, 2015 at 1:06 PM
    #1617
    OZ-T
    Peter North
    British Columbia
    So Zach , I posted this question about 40 pages back , just revisiting it as I try to figure put my options
    Are you still limited to doing the longbed cap rack rails in steel ?
  18. Mar 5, 2015 at 1:08 PM
    #1618
    zscott
    Zach
    Utah
    Nope. Long bed is now aluminum as well. The new shop I am using is much more talented and although they mentioned seeing the same issue on some jobs my parts are not affected due to the size of sheet they are using. Plus they are much better at using their equipment.
    Kgrecurit88 likes this.
  19. Mar 5, 2015 at 1:14 PM
    #1619
    OZ-T
    Peter North
    British Columbia
    Awesome
    I'm trying to decide how I want to do my cap rack , and that would dictate whether I could get your standard height cab rack or whether I would need it a custom height
    How do you approach mounting the cap racks on a set up like mine that just has the 4 feet ?
    FWIW the bases for the feet are just inside the dimensions of the cab rubbers
    ie outside to outside of the cap feet is essentially the same measurement as inside to inside of the cab rubber strips
    I would like the cap and cab rails to line up width-wise as well as height-wise and therein lies my dilemma
  20. Mar 5, 2015 at 1:29 PM
    #1620
    zscott
    Zach
    Utah
    Sounds like either way I would likely have to do a custom rack for you. My topracs aren't likely to line up with the mounting points that your crossbars on the topper are currently mounted to. I would have to readjust the toprac to fit those and then possible add some more mounting points in the middle to reinforce it. Unless you were to install some tracks then it would be another story. Either way though you are looking at drilling some holes in your shell.
    If it were me I would probably leave the bars on your shell now to save the need to drill or modify anything and just do the custom height cabrac. Totally up to you though.
