Prinsu Rack, 3 pair of LEDs from sPOD wiring Question
Discussion in 'Lighting' started by jtoelle, Apr 8, 2019.
  1. Apr 8, 2019 at 12:22 PM
    jtoelle
    jtoelle [OP] Well-Known Member
    LBC
    Hey guys, two questions.
    Need help from you expert wiring professionals.
    Need to wire 3 pairs of LED lights to my Prinsu from 1 port on the sPOD.
    1. I ran a Positive and Negative up the windshield trim to the Rack, whats' the best way to split the Positive to the 3 pair of lights?
    2. I also figured out, correct me if I'm wrong, but the Rack acts as a Ground so the Negative wire isn't needed, is this true?
  2. Apr 8, 2019 at 5:50 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    first you need to see if the one port on the spod can handle 3 pairs of lights. so check that first.
    1. just run them to the first then split it to the next and so on. a good crimp connector is best, but if you cant do that solder is the next best. (unless you cant solder very well either lol)
    2. totally depends. check the continuity between the rack and the neg battery. if its good, then you can use as a ground. i generally still run the ground to a central ground point.
