Prinsu roof rack holes for roof moldings?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDOFFRD510, Nov 28, 2018.
  1. Nov 28, 2018 at 9:29 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    That's the same kit I used and it turned out great. Cut the metal strip on the underside of the moulding a little bigger than the hole. I used painters tape on the side of the drip channels and then reinstalled the moulding to mark for cutting. Recheck the placement of the remaining holes after each punch to ensure a precise fit.
    Phoosa[QUOTED] likes this.
  2. Nov 28, 2018 at 10:03 PM
    droche
    droche Member
    Seattle
    2017 TRD Sport Access Cab 5MT
    I have a gasket punch set (you can find on Amazon or Harbor Freight), and fortunately have a small arbor press in my shop that makes it super easy
  3. Nov 28, 2018 at 10:07 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Cut the metal strip with snips, then 3/4" spade bit at slow speed. Easy cheesey.
  4. Mar 20, 2019 at 6:47 PM
    QuickSandNC
    QuickSandNC Active Member
    Travis
    2021 Toyota Tacoma TRD Off-road 4x4
    Guys I don’t have my roof trim anymore and need it because I just got a prinsu rack. ANYONE have a source on the molding? Can’t find anywhere
  5. Mar 20, 2019 at 7:01 PM
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    You don't need the drip molding..
    but here
  6. Mar 31, 2019 at 9:00 PM
    dan81finn
    dan81finn Well-Known Member
    Dasn
    2015 Tacoma TRD
    Has anyone had the OEM roof rack and then bought the prinsu? Can you just mount the prinsu and not have any leaks? The dealer wants 270 bucks for the drip moldings, and I’m tempted to pay it. I don’t want any leaks and I don’t want it to look like crap. Any suggestions?
  7. Mar 31, 2019 at 9:12 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    i tired it and it "kinda worked" but i ended up just using the ends in front and behind the rack
  8. Apr 26, 2019 at 9:55 PM
    Thetacotruck71
    Thetacotruck71 Well-Known Member
    James
    2019 TRD Off Road
    Does the section that was cut out fill with water?
  9. Apr 26, 2019 at 10:06 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    It wont just be sure that you use a good amount of sealant silicone around and inside of the spacers.
  10. Mar 9, 2023 at 5:50 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    That’s odd, 2nd and 3rd OEM ROOF RACKS are interchangeable.
  11. Sep 1, 2023 at 10:07 AM
    puja21
    puja21 New Member
    Adam
    2021 Gray Tacoma TRD Pro
    I just got one of these racks and peeled my factory Trim off to punch the holes.
    It was the night after a decent rainstorm and there was considerable water all along the drip track.
    Trim had never been touched before -- the factory 3M adhesive was original and the bolts were still stickered over, and the factory paint had been sprayed right over the sticker.
    My belief is you get water in the track no matter what
    I imagine the recommended silicone is to keep it from getting into the bolt holes -- tons of pics of rusted or seized bolts on these forums and/or people recommending copper anti seize when you install (or swapping to stainless bolts).
    I'm in very snowy part of the northeast so I'll report back someday with my experience.
