Prinsu Roof Rack, Sealing Screw Holes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RHED808, Mar 31, 2022.
  1. Mar 31, 2022 at 2:18 AM
    RHED808
    RHED808 [OP] -Zeke
    Hawaii
    2018 TRD Pro MT
    RIGID DSS PRO KO2 265/75r16
    Background,
    I installed the Prinsu roof rack October of 2021, didn't put in any sealant, and only put some silicon oil :annoyed:. Curious what everyone has used to seal the screw holes that attach the prinsu to the truck. I want to clean up and properly seal it before rust gets on the roof. If answered already please guide me in the correct direction.
    Thanks,
    -Z
    TacoGeeloor likes this.
  2. Mar 31, 2022 at 2:32 AM
    m shark
    m shark Well-Known Member
    Infinity QX-50, E46 M3
    I have the KC M-rack but I dabbed a squirt of silicon onto the screw holes where the spacers go, then I also squirted more silicon into the threaded hole before tightening the mounting screws.
  3. Mar 31, 2022 at 2:42 AM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    I used some silicone around the bolt holes and the bolts themselves. With that being said I will be taking them out once the drier weather arrives here in Washington and swapping them out with stainless steel hardware to prevent rust. I will again seal them with silicone. A good idea is to “cap” seal the head of the bolts also to prevent moisture from getting under the head of the bolts and creating corrosion issues. Just my 2 cents!
  4. Mar 31, 2022 at 4:20 AM
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    I used big ol gob of rtv in each bolt hole and the trim piece fits very snugly around the riser so far everything has been water tight for almost 2 years
  5. Mar 31, 2022 at 7:12 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I also used RTV into the screw hole. Too many "Leaky" stories for me, had to use some preventive measures.
