Prinsu
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlackRoan, Nov 1, 2018.
  1. Nov 1, 2018 at 12:48 AM
    BlackRoan
    BlackRoan [OP] Well-Known Member
    2018 White TRD PRO
    Still working on it
    lookimg into purchasing a prinsu roof rack. I also love the custom look to @mesojdm roof rack as well. Just wondering if I should vinyl wrap the roof first. I read somewhere to help prevent any rusting. Is there any truth to this?
    Also is there anyone out there that makes alternative hood scoop grilles?
  2. Nov 1, 2018 at 1:05 AM
    Duvorak
    Duvorak Well-Known Member
    Rian
    WA
    2002 DC Tacoma Limited TRD
    Only thing I could say to it helping from preventing rust is it providing a rub barrier between the roof rack and paint(which you should probably put some sort of rubber material in between) and then silicone the holes where you'd install the riv nuts.
  3. Nov 1, 2018 at 4:53 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    The only place the track touches the roof (besides the spacers you bolt through) is right under the wind screen and you can get a piece of weatherstripping so that contact is not metal on metal. I bought a piece of clear 3m tape to put there, but messed it up so didn't end up using it like other people have.
    There is a prinsu forum here and a ton of information in the bs thread. You should check that out of you haven't.
  4. Nov 1, 2018 at 4:56 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  5. Nov 1, 2018 at 6:27 AM
    lenriquez
    lenriquez IG: @les.enriquez
    Les
    Virginia Beach
    2017 Cement TRD Pro
    +1, I would look into powdercoating/painting the bolts that go into the roof as they seem to be the only things I can see rusting on mine.
    I also used this strip for the wind deflector, just needed to cut it to size.
    https://www.amazon.com/dp/B01ANO6RVI
  6. Nov 1, 2018 at 12:05 PM
    BlackRoan
    2018 White TRD PRO
    Still working on it
    Thanks fellas. I have noticed in photos some have wrapped there roofs and was thinking that may be to prevent rust and/or to minimize the paint being damaged due to dirt you cannot clean
