Pro comp 1069 on 1st Gen??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Feb 10, 2012.
  1. Feb 10, 2012 at 8:08 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    I might get some pro comp 1069 rims on my 2003 Tacoma. I read some where that the center caps wont fit is this right? Any problems that you guys had with this rims let me know please.
  2. Feb 10, 2012 at 8:36 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    its a pretty common wheel type. search some of the tire and wheel threads and maybe you'll see some.
  3. Feb 10, 2012 at 8:43 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    These rims come with center caps, yes they will fit. If you see people running these rims without center caps, it's because they chose not to run them.
  4. Feb 10, 2012 at 8:55 PM
    Hektor
    Texas
    Cool, so your center caps fit just fine. Also whats the part # I need to order. Is the 4 backspace good for our trucks?
  5. Feb 10, 2012 at 9:00 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    You might want less backspace if you're going with bigger tires.
  6. Feb 10, 2012 at 9:04 PM
    Hektor
    Texas
    Im gonna run the stock size 265 70 16 Michellins ATX 2
  7. Feb 10, 2012 at 9:25 PM
    Tacomadude89
    Austen
    California
    Pro Comp only offers the 16 with 4.0" of backspacing.
    Be sure to get the LUG centric type and NOT the hub centric as they will not fit. The part number you need for 16's is: 1069-6883
  8. Feb 10, 2012 at 9:40 PM
    Hektor
    Texas
    Thank you!! Brother. Ill let the guy from discount tire know.
  9. Feb 10, 2012 at 9:44 PM
    MLB YOTA
    MLB YOTA Young Gun
    Marshall
    Martinsville, VA
    Toyota Tacoma 4X4
    3" Pro Comp lift, Truxedo tonneau cover, brush bar, Sony Xplod cd player and Memphis speakers, 8" Dual Sub, JDM black tail lights, black headlights, corners, and turn signals, aFe pro dry S air filter, Deck plate, etc.
    I have the 1079 same thing they just have the simulated beadlock. My center caps up front wouldn't go on easy but nothing a little rubber hammer couldn't fix. I have taken them back off before, not easy but doable.
  10. Feb 11, 2012 at 4:03 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / ProComp 1069 wheels / 265/75-16 Michelin LTX tires
    Yes, I have Pro Comp 1069's and yes, the caps would not fit correctly. Not with a rubber mallet, not with a lot of force.
    They would not seat over the lip on the hub, it was very close, but not quite. I ended up putting approx six 3/8" scores in each cap and then used a rubber mallet to seat them.
    I know others noted that they had other options: either no trouble at all or hammered on, but that simply was not the case for me. I guess it is possible that there were changes at the factory to accommodate the issue during their production run.
  11. Feb 11, 2012 at 7:00 PM
    98 Taco Truck
    98 Taco Truck Active Member
    Norcal
    98 ex cab sr5 tacoma 4x4 trd
    3" toytec ultimate lift, elite offroad rear bumper and hybrid sliders,
    I have them in black on my 98 and I did not like the center caps that came with the wheels. They are an open center cap like for a vechile with selectable locking hubs. Then the plastic pro comp cover snaps into it, sometime they fly off or make noise when driving. I bought the all metal ones from Wheelers offroad. They fit perfect, infact the alloy wheels they used to sell were the procomp 1069.
  12. Feb 11, 2012 at 8:00 PM
    Hektor
    Texas
    Is it true that they are hard to balance and give to much problems since they are made in china?
  13. Feb 11, 2012 at 8:44 PM
    MLB YOTA
    MLB YOTA Young Gun
    Marshall
    Martinsville, VA
    Toyota Tacoma 4X4
    I haven't had any trouble with them as far as balancing. I've had mine for about 20,000 miles and I have changed the tires.
  14. Feb 11, 2012 at 10:28 PM
    Tacomadude89
    Austen
    California
    They're nice quality rims, no problems balancing or any issues...
  15. Feb 12, 2012 at 7:02 PM
    98 Taco Truck
    Norcal
    What he said :D
  16. Feb 13, 2012 at 10:56 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    If I am correct if the item # ends with a 83 should fit a Tacoma.
  17. Feb 13, 2012 at 9:59 PM
    lil J
    lil J Well-Known Member
    Jacen
    Louisville
    99 Tacoma 4wd V6 Horizon Blue
    Old Man Emu Suspension
    if you get those wheels give us an update on how they work out. I've been wanting to replace my 20's and I like those a lot.
