PRO COMP 1069....what's the deal?????????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Apr 3, 2011.
  1. Apr 3, 2011 at 6:06 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    So after searching a bunch of threads I get 50% response that the wheels did not fit and or I had to grind my calipers, and 50% response that the wheels fit. I have a 2009 4x4 and would love to get these wheels....for the people that had the grind the caliper...was it hard? Does it void the warranty?
    1069-6883
    16x8, 6 on 5.5 Bolt Pattern
    Backspace = 4 in.
    Max Load = 2200lbs
    Finish = Polished
    Hub Centric = No
    Offset = -11mm
  2. Apr 3, 2011 at 6:48 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    upgrade to the 17 x 9 and not worry about clearing the calipers.
    Item model number: 1069-7970
  3. Apr 3, 2011 at 7:12 PM
    TOYOTA 09
    Maine
    The 17x9 only has a -6mm offset....they won't stck out as far as the -11mm offset on the 16x8 right?
  4. Apr 3, 2011 at 7:14 PM
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    You're talking millimeters. Remember it's an 8" wheel versus a 9" wheel so right off the bat it's going to stick out one more inch, and two inches over stock
  5. Apr 4, 2011 at 4:52 AM
    TOYOTA 09
    Maine
    Okay.... So the 17x9 measurement means the wheel is 17 inches tall (diameter) and 9 inches wide?
  6. Apr 30, 2011 at 8:15 PM
    TOYOTA 09
    Maine
  7. Apr 30, 2011 at 8:16 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Yeah, that's correct.
