Pro comp 3 inch lift
Discussion in 'Suspension' started by Rkuchar, Dec 23, 2018.
Anyone else find that the 3inch coil spring lift is beyond stiff?
  1. Yes
    0 vote(s)
    0.0%
  2. Mine is also really stiff
    0 vote(s)
    0.0%
  1. Dec 23, 2018 at 10:33 PM
    Rkuchar
    Rkuchar [OP] New Member
    2011 Toyota Taco 4WD 4.0L Double Cab
    I installed Pro Comps 3 inch coil spring lift front and add a leaf rear. I also put on the JBA uca's. I installed it all myself and it ended up lifting my truck 4.75 inches in the front. It settled after flexing it offroad less than half an inch. It's a double cab 4.O L. It has about an in off movement when I put a jack under it. It doesn't feel right and the front sits under 3 an inch higher than the back.
  2. Dec 23, 2018 at 10:36 PM
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    Have a link for the front lift? I have procomp's 3 inch leveling kit and it has procomp struts/coil springs up front. Lift is about 2 inches up front. But I want to go more. Please share a link if you have and pictures would be great too
  3. Dec 23, 2018 at 10:41 PM
    Rkuchar
  4. Dec 23, 2018 at 10:41 PM
    Dawdaw808
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
