Pro comp 3" lift or Rancho Quick Lift and AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UAByota1, Feb 26, 2015.
  1. Feb 26, 2015 at 12:27 PM
    UAByota1
    UAByota1 [OP] Member
    Alabama
    07 TRD offroad
    Hey I am new to TW but I have been reading as a guest for a while. I have seen some pretty good discussion on the pro comp 3" and it has made me look into another option. What do you all think about the rancho quicklift and an AAL? Will I be better off going this route?
  2. Feb 26, 2015 at 12:58 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    Why are you dead set on Rancho or Procomp? From what I've read deciding between those two options is like choosing to eat shit or drink piss.
    If you are on a budget check out bilstein 5100s.
  3. Feb 26, 2015 at 1:22 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Same with Rough country..do it once, do it right.
  4. Feb 26, 2015 at 1:24 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    This
    x2
    spacers suck
  5. Feb 26, 2015 at 1:26 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Bahahaha! Great analogy! +rep
  6. Feb 26, 2015 at 1:28 PM
    UAByota1
    Alabama
    07 TRD offroad
    Thanks for the Welcome! Im not dead set on either of these just trying to stay under $500 to apease the wifey! I really want the Icon but I only street my truck with the once a year trip down a dirtroad or trail ride so $1100 is just out of the question I will check out the Bilstein now thanks for the suggestion.
  7. Feb 26, 2015 at 1:28 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Thanks! :D
  8. Feb 26, 2015 at 1:32 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    I think the cheapest Icon Kit (Stage 1) is right around $1500.
  9. Feb 26, 2015 at 1:33 PM
    geekhouse23
    It's easier to ask for forgiveness than permission OP
    :D
  10. Feb 26, 2015 at 1:49 PM
    UAByota1
    Alabama
    07 TRD offroad
    This is true.
  11. Feb 26, 2015 at 1:52 PM
    UAByota1
    Alabama
    07 TRD offroad
  12. Feb 26, 2015 at 1:52 PM
    geekhouse23
    What is the desired lift height? Anything over 2.5" you need UCAs
  13. Feb 26, 2015 at 1:55 PM
    UAByota1
    Alabama
    07 TRD offroad
    I really wanted 3" to run 305/70-16 BFG's
  14. Feb 26, 2015 at 1:56 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    "need" (for UCAs) is relative. If you're trying to stay on a budget, you can add the UCAs later if/when you get tired of the "twitchy" feeling in the steering.
    UCAs are require to re-align the "Caster" adjustment which affects how the truck feels/drives, not how the tires wear.
  15. Feb 26, 2015 at 2:57 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Those tires will be tough even with 3". 285/75R16 is what most guys go with, even then some trimming of the plastic wheel well may be required. Also look at getting rear axle shims and do your research here on driveline vibrations after lifts. Do the UCA's at the same time, you'll save yourself an alignment and a lot of work.
  16. Feb 26, 2015 at 3:17 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Get the Icon. Put in on. Tell your wife later. She'll get over it. Good quality suspensions are like guns and tools....not a bad investment.
