Pro Comp 3" lift
Discussion in 'Suspension' started by rafranko, Sep 28, 2011.
  1. Sep 28, 2011 at 10:54 AM
    rafranko
    rafranko [OP] Active Member
    Rob
    virginia
    08 Double Cab long bed
    crossfab light bar, toytec leveling kit, hella off road lights,
    Looking for recommendations on where to order a pro comp 3" lift from. Online best i can find is about 460 w/o shipping. I've seen older threads where members were getting much better prices on this lift. Suggestions appreciated.
  2. Sep 28, 2011 at 10:56 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Its an ok lift...
    Id look for something of a bit better quality. However this comes with more money.
    I think I paid around 450 for mine shipped. but that was a few years ago.
  3. Sep 28, 2011 at 11:59 AM
    rafranko
    Rob
    virginia
    so you've had experience with this lift? what kind of issues did you run into?
  4. Sep 28, 2011 at 12:12 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Since ProComp is owned by the same parent company as 4 Wheel Parts, 4WP is probably going to have the best price.
    Be aware that the springs on that lift are the stiffest springs available for our Tacomas (I've heard 720lb/inch) stiffer than OME 886, stiffer than ICON coilover, stiffer than Eibach.
    So not really recommended unless you're running a heavy bumper and winch. Check StuntManHans' thread for his experience.
  5. Sep 28, 2011 at 12:14 PM
    RBPTaco
    RBPTaco Well-Known Member
    10 Tacoma 4x4
    Leveling kit, 285/70/R17 Elderado Tires, American Racing Wheels, Duel Flowmaster exhaust, RBP Grille
    I just had one installed by 4wp and i love mine
  6. Sep 28, 2011 at 2:02 PM
    Maverick904
    Kameron
    Northeast Florida
    I still run my lift..
    No issues really...just rides stiff as hell. Skips over speed bumps when going slow....doesnt absorb much when hitting them fast (ish). Its just a budget lift that shows in ride quality.
    Im also running a double cab (heaviest) and the ride is rough. So if you are running a lighter truck it can only be rougher.
  7. Sep 30, 2011 at 7:40 AM
    Conviction11
    Conviction11 Busting Asphalt
    J
    South Carolina
    I have the pro comp 3" lift and it's a bit stiff, but still rides fine to me. I had trouble compressing the springs so I paid a shop 250.00 to put it on and to do the alignment.
  8. Sep 30, 2011 at 7:47 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    4 wheelparts is have a sale oct 8 and you can probably going in get the lift for cheap and also I would recommend going in early so you can set up an appointment to get it install that day because its 50% off install
  9. Oct 2, 2011 at 11:05 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    No offense but I wouldnt waste time getting this lift. Trust me I've had it and I hated it. I personally called ProComp about the ride quality and a few other issues they advertise with the lift. First off it is a 718# coil up front, which is absolute overkill. I have a dbl cab, and the ride was total crap. They also claim that you can run 33x12.5x17 without new UCAs and that you will have perfect alignment. Crap. Even after doing the tire chalk test, and having a few different shops look at it, including my buddies, they all said that it is impossible to have proper alignment with that kit. When I brought it up to ProComp, they said sorry your problem. You'll regret it from the moment you put it on. More problems than good.
  10. Oct 4, 2011 at 9:19 PM
    jr114
    Jon
    SoCal
    Truck
    you sir are the only one ive heard say good things about this kit. not trying to discredit you, im just merely stating my experiences so that others can get both good and bad when trying to decide.
  11. Oct 4, 2011 at 9:22 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    I have this kit, its affordable and gets you up there. but it rides really stiff even with a front bumper. Coilovers on the way!
  12. Oct 6, 2011 at 2:43 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    As noted above, procomps overly stiff springs, paired with their twin-tube shocks, lead to quite a harsh ride when compared with other lift kits.
  13. Oct 6, 2011 at 6:06 PM
    Blacktacoma23
    Denver
    A used set of Sway aways.
    X2.
  14. Oct 6, 2011 at 10:07 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  15. Oct 7, 2011 at 5:47 AM
    KPT
    09 Prerunner
    All coilovers CAN give 3" ;)
    They can be set to whatever height between 0 and 3" you desire
  16. Oct 7, 2011 at 9:21 AM
    Blacktacoma23
    Denver
    The bumper helped a little but it still rides like crap on every bump on the road.
  17. Oct 7, 2011 at 9:29 AM
    Maverick904
    Kameron
    Northeast Florida
    Any of you guys think the rear is stiff as hell as well?
  18. Oct 7, 2011 at 9:48 AM
    Blacktacoma23
    Denver
    Yeah, but im more worried about the front
  19. Oct 7, 2011 at 9:56 AM
    Maverick904
    Kameron
    Northeast Florida
    Ill have to get around to doin the chalk test soon. I think I have high ply tires as well which cant help.
    Sanding my grill as we speak ahaha.
