pro comp 3" lift
Discussion in 'Suspension' started by AirForceTacoma08, Jan 3, 2014.
  1. Jan 3, 2014 at 2:25 PM
    AirForceTacoma08
    AirForceTacoma08 [OP] Well-Known Member
    Adan
    From AZ but Utah living
    08 Taco DCSB
    URD CAI throttle body spacer doug thorley headers straight pipes magnalow muffler URD MAF Sensor Calibrator
    read all the threads i can but cant really find the answers im looking for, maybe not looking hard enough but anyway. i want to put a 3" in pro comp lift (springs and leaf pack) for now and i want 285-75-16. i was wondering how much it rubs and do i need new uca's? :confused:
  2. Jan 3, 2014 at 2:27 PM
    Robotoco
    Robotoco Well-Known Member
    Roberto
    NC
    3" lift and 33''
    all you need is spacer for your wheels and your good
  3. Jan 3, 2014 at 2:30 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    what size spacer?
  4. Jan 3, 2014 at 2:40 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah if you plan on keeping your stock wheels you will need wheel spacers....preferably Spidertrax 1.25" ones. For UCA's anything over 2.5"s of lift they highly recommend them to get the alignment right but I know people that dont run them.
  5. Jan 3, 2014 at 2:44 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would recommend new uca's.
  6. Jan 3, 2014 at 2:52 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    what ucas's do recommend?
    i was looking at total chaos but those are pretty pricey :(
  7. Jan 3, 2014 at 2:53 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    I have the same lift and run 285's. 4.5" backspace rims and only rub a little on the frame and body mount. Doesn't rub enough to warrant any more than a little plastic trimming. The Procomp spring is stiff so you won't get a ton of flex out of the front. Do yourself a favor and scuff/paint the springs before install, factory paint sucks.
  8. Jan 3, 2014 at 2:54 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    Oh, and stock UCA's. No alignment issues.
  9. Jan 3, 2014 at 3:02 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    thnx man and 4.5"??? how far to your tires stick out from the fenders :eek:
  10. Jan 3, 2014 at 3:17 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    ....1"- 1 1/2"? not too much.
  11. Jan 3, 2014 at 3:26 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op go on wheelersoffroad website get bilstein 5100 all around better ride and the front shocks can be adjusted to 2.5 in lift and the rear either a addALeaf or they do offer a leaf pack.
    If you wana keep the stock wheels I recommend getting spider trax 1.25 wheelspacers
    Uppers if you dont wana spend 600-700 on uniball
    Then go with the light racings there about 400 bucks I believe.
    Reason on aftermarket uppers you get better alight ment and won't wear out yours tires.
  12. Jan 3, 2014 at 3:30 PM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    x2.... the procomp makes a harsh ride.
  13. Jan 3, 2014 at 3:35 PM
    na8rboy
    WI
    As for UCA's, it all depends on budget. I like the Camburg ball joint. Everyone will have their own opinion on this subject. I like them, because they are sealed and you grease them.
    I second the Bilstein 5100 route.
  14. Jan 3, 2014 at 3:40 PM
    BAMFTACO
    Juan
    Kings bruh
    I've ran the pro comp 3 inch lift before it sucks shocks are horrible and they blew out on my quick. Spacer lift stay away.
    So op I recomend doing it right the first time so your not redoing later. you'll end up spending more money trust me with the money I've spent over the years on doing the wrong things and going cheap I could of had a bitchin set up but you live and learn.
    Hope this helps.
  15. Jan 3, 2014 at 4:05 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
  16. Jan 3, 2014 at 4:06 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    thnx guys 5100 sounds better and is priced better
  17. Jan 3, 2014 at 4:09 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    whats the difference between 5100 and b1101 5100 on rear shocks
  18. Jan 3, 2014 at 4:15 PM
    AirForceTacoma08
    Adan
    08 Taco DCSB
    any complaints about toytec ultimate tacoma lift??
