Pro Comp 3in spacer lift!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calaniz0312, May 1, 2010.
  1. May 1, 2010 at 10:21 AM
    calaniz0312
    calaniz0312 [OP] Well-Known Member
    Carlos
    Mission, TX
    05 PreRunner SR5
    Pop a Lock tail gate lock, Dee Zee Heavy Duty bed mat, Viper alarm system, Blacked out headlights, Blacked out tailights.
    I know this isn't a top of the line lift and I haven't heard to many great things about spacer lifts, but I'd like to get some feedback from someone who has or has had this lift. How is it?
  2. May 1, 2010 at 10:25 AM
    calaniz0312
    Carlos
    Mission, TX
    05 PreRunner SR5
  3. May 1, 2010 at 2:19 PM
    calaniz0312
    Carlos
    Mission, TX
    05 PreRunner SR5
    bump again!
  4. May 1, 2010 at 2:34 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Spacer lifts compress your coils and therefor give you less travel which gives you a stiffer ride. It is fine if you just want the looks you cant really notice the ride difference on the streets, but when you get offroad you will notice the difference. But it is a cheap way to gain lift and allow for bigger tires if you dont do much offroading.
  5. May 1, 2010 at 2:38 PM
    calaniz0312
    Carlos
    Mission, TX
    05 PreRunner SR5
    Thanks.
  6. May 1, 2010 at 2:38 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    No problem, good luck
