pro comp 6" drop bracket reliability??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HI2vegas, Jun 3, 2011.
  1. Jun 3, 2011 at 9:01 AM
    HI2vegas
    HI2vegas [OP] Active Member
    Michael
    Las Vegas
    2013 toyota tacoma 4x4 offroad package
    i just bought a new 2011 tacoma access cab 4x4 and im ready to lift it. i like the look of the 6" pro comp lift but i was told that the drop brackets are weak and i cant off road with them. i do plan to go off roading but nothing extreme. if anyone has any info on this or has the 6" pro comp and off road there tacoma, i would apprieciate any suggestions. my other option is the 3" icon lift but i like the 6" look better.
  2. Jun 3, 2011 at 9:07 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Welcome.
    If you your not wheelin hard you should be fine with a drop bracket. You just get more ground clearance at the Diff with a 3" lift. and with a higher truck you risk rolling easier with the limited down travel of the IFS. Off camber is a little more ass puckering with a 6" lift on IFS
  3. Jun 3, 2011 at 9:08 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    I've wheeled mine a lot and never had a problem. Rides good around town and isn't a bad way to achieve lift
  4. Jun 3, 2011 at 9:35 AM
    HI2vegas
    Michael
    Las Vegas
    thanks. if i go with the 3'' coilover then add a 2 or 3" body lift, is there problems that i could run into?
  5. Jun 3, 2011 at 9:38 AM
    JLee
    Jerry
    Bay Area NorCal
    Don't go over 1" on a BL there is too many problems with BL's over 1" if you want 6" of lift just get the drop bracket lift.
  6. Jun 3, 2011 at 9:43 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yes some people crack their frame around body lifts. i highly suggest not going with a body lift.
    the 6 inch life is fine, just not as much clearance
  7. Jun 3, 2011 at 10:06 AM
    HI2vegas
    Michael
    Las Vegas
    cool thanks. i think im gonna stick with the 3" lift. sounds like ill run into to much issues with the 6". making the call to order the icons now. thanks again.
  8. Jun 3, 2011 at 10:15 AM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    I second that. I had the procomp 6" for a couple years and wheeled it a good amount of times. Never had an issue
  9. Jun 3, 2011 at 11:15 AM
    PLC721
    Patrick
    Chandler, Az
    we just like LT ;)
