Pro comp 6" lift limiter blocks, necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bren5279, Aug 9, 2015.
  1. Aug 9, 2015 at 8:15 AM
    bren5279
    bren5279 [OP] Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    How necessary are the block stops that space down the rubber bumper? It looks like the wheel could come up quite a bit more without them. Yes I'm aware the shocks would bottom out, but it appears that they can still go quite a bit further than where the blocks stop them. Anyone ever messed with these?
  2. Aug 9, 2015 at 8:20 AM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    I would do just about anything to prevent bottoming out on a shock. If you make mods to the blocks, just make sure those bumps are still functional before you take the truck out. Otherwise, stick to using the kit as it was designed. My two cents.
  3. Aug 9, 2015 at 8:21 AM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    I'm curious to see what people have tried, too, to up their wheel travel with a drop bracket lift...
  4. Aug 9, 2015 at 8:25 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    They do seem to limit the travel a lot. I'm sure they are built on the conservative side to keep the shock from bottoming out and your tire from eating your fender and cab mount. You would need to figure out how much travel your shocks have and then clearance everything.
    Edit:You could also ask in the drop bracket thread in the suspension section of the forum,those guys have a lot of experience with this stuff.
  5. Aug 9, 2015 at 8:29 AM
    techride
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    And remember that the bump stops compress a bit as well under hard bottoming.
  6. Aug 9, 2015 at 12:59 PM
    bren5279
    Brendon
    new bern NC
    Thanks for the inputs. I may mess around with it a bit later and see just where the shocks limit it and the bump stop compressibility.
    Rock lobster- you may want to look at the suspension layout again and read up on block drops. If the axle is already lower than originally at, then allowing it to go up to where it started at won't hit anything. Now further down travel while turning may bind them, but not going back up to stock upward angles...
