pro comp 7089 hub caps chipped when tire rotation is that normal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoodratstormtroop, Aug 26, 2011.
  1. Aug 26, 2011 at 10:41 PM
    hoodratstormtroop
    hoodratstormtroop [OP] Well-Known Member
    santa cruz
    2006 4x4 tacoma TRD debadged
    GPS/dvd player in dash, tires, rims, window tint, tail lights, and sub.
    on my pro comps 7089 my hub caps chipped when i got a tire rotation is that normal?
  2. Aug 26, 2011 at 10:43 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    :worthless:
    How bad is it?
  3. Aug 26, 2011 at 10:45 PM
    hoodratstormtroop
    santa cruz
    just chips on the hub caps ! just wondering if this has happened to others.....
  4. Aug 26, 2011 at 10:46 PM
    hoodratstormtroop
    santa cruz
    20% of the paint on each cap is gone Crome spots
  5. Aug 27, 2011 at 8:21 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    I'd say over 50% of the paint is scrapped off the sleeves that go over the hub with my 7089's.
  6. Aug 27, 2011 at 7:23 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    My 7089's do the same the center caps stay stuck on the hub when I rotate the tires. You just have to be super careful when sliding the wheel over the cap.
  7. Aug 27, 2011 at 8:07 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Same thing happened with mine. I plan on buying new ones and using a thin coat of scotch tape over them when I take off the wheel.
  8. Aug 27, 2011 at 9:06 PM
    DueNorth
    ^ I thought about using some sort of clear tape as well, but I'm not so sure it will hold up over time with metal on metal rubbing while taking off the wheel. It would be hard not to touch it. Especially if you rotate every 5 000 miles, that gets to be a lot. Painting and scotch taping the original sleeves would probably be cheaper and easier than ordering new ones, especially if the tape doesn't work out.
  9. Aug 28, 2011 at 7:30 AM
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Same thing happens to mine. The center caps are garbage and they don't fit the hub properly.
