pro comp 7089 series and tire question
Discussion in 'Wheels & Tires' started by KJK, Jun 27, 2012.
  1. Jun 27, 2012 at 8:10 PM
    KJK
    KJK [OP] Member
    PA
    tacoma
    Sorry to post this but I read through alot of info and I'm not confident to make my own decision without asking directly. I have an 09 tacoma 4wd with 3inch pro comp lift and I'm wondering if the 7089 series 16x8 pro comp rims with 0mm offset and 4.5"backspace will work with tires up to 275/85/16 without having to make any body modifications. Should I go with rims that have 4" backspace instead? Whats the biggest tire that will work without cutting up fenders?
  2. Jun 27, 2012 at 8:18 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    These are 7089s with 285/75R16 and maybe 1.5" lift. They barely hit fender flare when turned and bounced. They have yet to hit body mount, a-arm, or frame. I haven't done any "trimming" either.
  3. Jun 27, 2012 at 8:27 PM
    KJK
    KJK [OP] Member
    PA
    tacoma
    Thanks for the quick response. Would my 3inch lift help any with clearance or is that just a matter of less backspace? Would it be a better decision for me to choose the rim with a 4" backspace?
  4. Jun 28, 2012 at 4:39 AM
    KJK
    KJK [OP] Member
    PA
    tacoma
    anymore advice?
  5. Jun 28, 2012 at 7:07 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    with 4" BS you'll rub more than with 4.5"
  6. Jun 29, 2012 at 9:33 AM
    KJK
    KJK [OP] Member
    PA
    tacoma
    So I placed an order with 4wheelparts.com on the 7089series 16x8 and they told me I needed to go with the 17x8 to clear the caliper on the 09 tacoma. Is this true with any 16x8?
  7. Jun 29, 2012 at 10:35 AM
    TexasTacoma37
    They are wrong. They always tell people that. Several members run the 7089 in 16 with no issues.
  8. Jun 29, 2012 at 11:43 AM
    DWreck
    Derek
    Las Vegas, NV
    :wave:
  9. Jun 29, 2012 at 11:48 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I have 7089 16x8 with 4.5 BS and they fit fine....but I have the TRD off road which came with 16" rims, I have seen people with the sports that come with factory 17" have issues fitting other rims like Micky Thompson but not the 7089 that I can remember
  10. Jun 29, 2012 at 2:02 PM
    KJK
    KJK [OP] Member
    PA
    tacoma
    Thanks guys I emailed pro comp directly and I'll see what they say about it. I really don't see why they wouldn't fit since the factories are 16" as well.
  11. Jun 29, 2012 at 2:38 PM
    DWreck
    Derek
    Las Vegas, NV
    The only way I see them hitting the caliper, is if when balancing, they stack the sticky weights more than 2 high. In that case, the weights would hit the caliper.
  12. Jun 29, 2012 at 3:33 PM
    TexasTacoma37
    Pro comp is owned by 4 wheel parts, so they will tell you the same thing I'd imagine.
