pro comp bar???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Jan 23, 2010.
  1. Jan 23, 2010 at 8:54 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  2. Jan 23, 2010 at 9:01 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    couldn't tell you, but the pic looks like you have to put holes in your bumper...yuck.
  3. Jan 23, 2010 at 9:02 PM
    kinkrider101
    santa barbara
    wheels and tires
    ya you need holes, im debating betweenpro comp or n-fab. Where can i buy a wiring harness for 3 lights.
  4. Jan 23, 2010 at 9:36 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    your harness will come with the lights, or you can always make your own with a simple relay.
  5. Jan 23, 2010 at 9:43 PM
    kinkrider101
    santa barbara
    wheels and tires
    is there a wiring kit i could use?
  6. Jan 24, 2010 at 12:11 PM
    kinkrider101
    santa barbara
    wheels and tires
  7. Jan 24, 2010 at 12:58 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    not sure what you mean...when you get lights should come with all necessary wiring and relays.
  8. Jan 24, 2010 at 1:15 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I have this but did not drill holes to the plastic bumper. I only drilled to the to the aluminum frame for the mounting points of the bottom bar. It is very sturdy. I just let the ends of the top bar sit on the bumper but I added protection (like velcro) to avoid scratches.
    Sandman427 in the banner has the same light bar.
  9. Jan 24, 2010 at 1:27 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    No wiring harness in mine.
    Here's the wiring diagram I used.
    You will need relay, switch, fuse holder, fuse, wires and connectors. If you will tap to the fuse box, you'll need mini fuse tap and mini fuse. Make sure to use correct size of wire, fuses and relays. All are dependent on the total current consumption of your light setup.
    Check out the mods/tutorials section for more tips and instructions.
    Good luck.
