pro comp is this what i need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, May 31, 2011.
  1. May 31, 2011 at 6:09 PM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
  2. May 31, 2011 at 6:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The most affordable, but still good quality lift, is going to be bi stein 5100s for the front, and an add a leaf for the rear. Under $300 total.
  3. May 31, 2011 at 6:19 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Am I wrong or is that for a truck with a solid front axle??
  4. May 31, 2011 at 6:21 PM
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    4 inches is way to high since your a 4x4, your cv angles will be bad. For cheap lifts most run 5100 adjustable shocks (up to 2.5 inches front) and an AAL out back. Check out Downsouth Motorsports, they are a vendor on here.
    Also, I don't think that lift is even for our trucks?
    3 inches is really all you want to go before heading to drop bracket lifts, and to add to that you'll probably need new UCAs for proper alignment.
    Search is your friend. Tons of information on this site about all the different lifts and what you'll need.
