Pro comp lift...
Discussion in 'Suspension' started by toyo freak, Feb 13, 2011.
  1. Feb 13, 2011 at 1:47 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Ok so looking at procomp 3" suspension because I can't afford much more. I know it's not a very good lift and rough ride because the coils have a 700 pound spring rate. My question will adding a heavy bumper like arb with this lift on a double cab help smooth out the ride ? Or is that too much for procomp shocks? I dont know what ome 886 are but I imagine they are around 650lbs. Any input is appreciated
    EDIT: I have decided against the bumper, so now this thread is open to anyone with the pro comp 3" lift who wants to share their experiences.
  2. Feb 13, 2011 at 1:49 PM
    francis1291
    francis1291 Well-Known Member
    10 4x4 SR5 super white
    3" procomp lift wit 20" rockstars on 33 toyo mt's
    i have the 3 inch lift....i like mine alot but the ride is a little rough but nothing major.
  3. Feb 13, 2011 at 1:51 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You don't sound so excited about the lift. How much is it?
    You can get bilstein 5100's for the front and an AAL for the rear for about $300.
  4. Feb 13, 2011 at 1:51 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    blisten 5100's!
  5. Feb 13, 2011 at 1:56 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2, and if you wanted OME 885/886 springs, they are only $160 more for a good combo.
  6. Feb 13, 2011 at 1:57 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    I think the Pro Comp is around $450-500.
    Like the 5100s, but I would rather a complete 3" lift.
  7. Feb 13, 2011 at 1:57 PM
    BlueTaco07
    Cody
    Looking
    Bliten 5100's go up to 3' and in the back just AAL
  8. Feb 13, 2011 at 2:00 PM
    KPT
    09 Prerunner
    You can get a thin a 1/2" top plate spacer on the billys. They are like $20.
    However, if you go over 2.5" of lift, you will likely need new UCA's to get your alignment right.
  9. Feb 13, 2011 at 2:01 PM
    francis1291
    why does every1 dislike pro comp?? i got mine for 400 shipped
  10. Feb 13, 2011 at 2:02 PM
    BlueTaco07
    Cody
    Looking
    I dont dislike i got procomp too, but blisten5100's are cheaper and just the better way to go
  11. Feb 13, 2011 at 2:06 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    No they dont. Up to 2.5
  12. Feb 13, 2011 at 2:08 PM
    BlueTaco07
    Cody
    Looking
    My bad, got mixed up with pro comp suspension lift
  13. Feb 13, 2011 at 2:09 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    But is that too much preload. I am pretty sure they do not reccomend running top plate spacer with billies.
    Yea I know I will need new UCA, but they can wait
  14. Feb 13, 2011 at 2:10 PM
    KPT
    09 Prerunner
    Top plate spacers do not preload the spring.
    They don't recommend running a thin top plate spacer on them because it will get you over 2.5" of lift, which will require new UCA's.
  15. Feb 13, 2011 at 2:11 PM
    Incognito
    VA
    Here's an option:
    Bilstein 5100's for all 4 corners - ($300 from Downsouthmotorsports)
    2" (or 1.5, depending on if you have the rear spring TSB) - $80
    OME 885 front springs - $160
    Total is $540 and you have a good lift for the money. I bet the Procomp would work fine, but from everybody I've talked to the ride has been very rough.
  16. Feb 13, 2011 at 2:12 PM
    BlueTaco07
    Cody
    Looking
    x2
  17. Feb 13, 2011 at 2:20 PM
    BlueTaco07
    Cody
    Looking
    Truck looks great bro :)
  18. Feb 13, 2011 at 2:22 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Nice! What size tire?
  19. Feb 13, 2011 at 2:27 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Exactly why I am asking if adding 200lbs of front weight with a bumper would help. My buddy has this lift and it is rough but he has an extended cab. Alot of people say its rough, but they running it on an extended cab, which is lighter than a double cab. So I am wondering if combined weight of double cab and bumper would help with the ride.
  20. Feb 13, 2011 at 2:30 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    The way I see it: Every truck is different and requires certain springs. Compare OME 884,885, and 886. 884 is for lighter extended cab, 885 is for the 100lbs of extra weight of double cab, and 886 is for 150lbs of bumper,winch etc. I really need to compare coil spring rates. :) Any one have the numbers....chris4x4, where are you? :)
