Pro Comp lift
Discussion in 'Suspension' started by rpoint16, Jan 30, 2009.
  1. Jun 13, 2009 at 7:45 PM
    JahFtb
    JahFtb Well-Known Member
    Such a newb question but what is more recommended for light to no off road usage the Toytec kit with spacers or coilover?
  2. Jun 13, 2009 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OME coils or Coil overs are better in all cases.
  3. Jun 13, 2009 at 7:51 PM
    JahFtb
    So your saying unless you EXTREMELY cheap the coil over kit for $299.99 is more reliable then the $229.99 spacer kit? ^is what is in mine
  4. Jun 13, 2009 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. And even if useing OME springs, you should use Bilstien 5100 shocks or OME shocks for best results.
  5. Jun 13, 2009 at 7:56 PM
    JahFtb
    soo then to top it all on a one stop shopping trip you are talking about these? correct?
  6. Jun 13, 2009 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  7. Jun 13, 2009 at 8:00 PM
    JahFtb
    sorry for the thread crashing but now i know 3" lift isn't as expensive as it's made out to be, and lastly what about install on a DIY level 1-10 is it something that can be tackeled with the instructions and common sense?
  8. Jun 13, 2009 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes...And a spring compressor. I would rate it a 3.5 out of 10. 1 being airing up a tire, and 10 being an engine rebuild. :)
  9. Jun 13, 2009 at 8:10 PM
    JahFtb
    well then in that case i'd be talking to some one more qualified to tackle it then, THANKS!
  10. Jun 13, 2009 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
