PRO COMP LIFT????
Discussion in 'Suspension' started by toyotatrav, Mar 1, 2013.
  1. Mar 1, 2013 at 5:59 PM
    toyotatrav
    toyotatrav [OP] Just me
    travis
    nevada
    09 tacoma crew cab
    magnaflow exhaust nerf bar steps, pioneer dvd head deck, TRD cai, remote start
    hello tacoma world, a few questions...
    to start out i have a 2009 tacoma crew cab 5' bed.. im looking for a 3"-4" lift for it. i found a pro comp lift kit that comes with es6000 struts and longer coil springs, es9000 rear shocks with add a leaf spring for about $450 bucks.
    Has any one bought and used this lift set up and if so how is the ride? we take long road trips in the tacoma so im NOT wanting a stiff ride.
    http://4wheelonline.com/Products.aspx?CategoryId=92436&ProductId=242047
  2. Mar 1, 2013 at 6:06 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    Have heard this lift is on the stiff side. If you want a good 4" drop bracket lift go with rcd, bds or zone. If you want a good 3" lift go with bilstein 5100's set at .85 w ebiach coils in front and a rear progresive leaf pack w rear bilstein 5100's. You will be happier in the end and get a much better ride
  3. Mar 1, 2013 at 6:19 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    ^^ This
    I have the same procomp lift. Not too bad, but stiff. Just put 5100's on the back, much better. Putting the front 5100 on the procomp spring to see how it rides. Depending how it rides, I wll toss them and get a set of OME's or something.
  4. Mar 1, 2013 at 6:34 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    i also looked at the 3" bilstein 5100 set up on toytec. but ill check out the 4" lift too.. i bought the truck with 305/50/20's on it.. not super excited about 20's but they look good on the truck.. ill go down to 18's one day
  5. Mar 1, 2013 at 6:43 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Go with bilstein stay away from procomp
  6. Mar 1, 2013 at 8:56 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    ok did a little homework, and so far i like the the 3" lift set up on toytech.
    let me ask another question... has anybody or heard of anybody useing a suspention lift kit like that (5100 bilstien struts w/coils, aal w/shocks) with a small 1" bolt-n-block and a spacer over the strut?
  7. Mar 1, 2013 at 9:12 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Highest you can go with lift on a tacoma without a drop bracket lift is 3'. Spacer lifts are pretty much frowned upon on TW. They make he ride much rougher. Which lift were you looking at? this one? ...also i was proven wrong today and found out the front diff drop is not needed on newer 05+ tacomas...
  8. Mar 1, 2013 at 9:12 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    i just realized what i wrote in my post, what i ment was and extra 1" block and spacer to get an extra inch of lift
  9. Mar 1, 2013 at 9:17 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    there were 2 different set ups i was looking at.. one had like a 800 and something # shock and one hasd a 600 something # shock.. i guess im looking for lift and a better ride. looking at 3" but aiming for 4", would like to stick with strut/coil in the front.. not wanting to get into spindles and a arm drop downs
  10. Mar 1, 2013 at 9:19 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    A block on the rear leaves? or up front?
  11. Mar 1, 2013 at 9:22 PM
    Droptine
    Droptine Active Member
    North Louisiana
    2013 TRD 6 Speed
    What is estimated cost on this 3" set up with 5100's (not installed) just hardware?
  12. Mar 1, 2013 at 9:25 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I *ACTUALLY* own the Pro Comp lift you're talking about. Its a great lift for the price. A lot of bandwagoneers will say that Pro Comp is junk but have never even ridden in a vehicle with one.
    Now, with that said, the lift is stiffer than stock, but by no means unbearable. If you're on a tight budget, feel confident with the Pro Comp, if you have some spare change laying around and can afford a bit more, go for one of the higher end lifts.
  13. Mar 1, 2013 at 9:29 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    one was for 919.99 and one was 649.99, i think i read it came with a 1 1/2 " rear block for the rear,, and aal.. so couldnt i go with a 2 1/2 block and a spacer above the strut not above the coil
  14. Mar 1, 2013 at 9:32 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    thanks pvt , i already have a somewhat stiff ride and i think its cuz there is a spacer between the coil and strut mount.. it was on the truck when i bought it last january. im gonna guess its so they could fit the 305/50/20 tires and rims
  15. Mar 1, 2013 at 9:33 PM
    BAMFTACO
    Juan
    Kings bruh
    I've had this lift and beat on it. Rear shocks blew out within a year and then for the front the bushing for the shock that connects to the lower arm starting to fall apart. So I do have experience with this lift and the reason why I say stay away from procomp
  16. Mar 1, 2013 at 9:35 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    It comes with eibach coils and 5100's. And an add a leaf in the back. The blocks can be combined with the aal. But only 3inches can be put up front. The spacer up front it s 1/4 inch spacer up front if you have a double cab because of the added weight. But you can't exceed 3 inches up front.
  17. Mar 1, 2013 at 9:43 PM
    toyotatrav
    travis
    nevada
    09 tacoma crew cab
    due to the front diff drop down right..? so i belive the diff drop down is a spacer drop down right? couldnt a guy get a longer bolt and spacer? just asking questions....
  18. Mar 2, 2013 at 4:11 AM
    BORNWILDGUY
    Rich
    Florida
    5100's for fronts and rears about 300-320
    ebiach's 180
    3 leaf pack 180-200
    This all is easy enough to do in your driveway or garage if you have the basic tools, floor jack and jack stands
