Pro Comp, OME, Fabtech, or skyjacker??
Discussion in 'Suspension' started by 4cyltacoma, Nov 10, 2010.
  1. Nov 10, 2010 at 8:58 PM
    4cyltacoma
    4cyltacoma [OP] Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    Which one would be a better buy. Good handling, off roading, and rides close to stock but not as stiff.. What are your opinions in these four lift kits??? Thanks price is around $2,000.000 or less.
  2. Nov 11, 2010 at 10:16 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    OME is the only one out of your list that I would recommend. If you are going for a taller lift (drop-bracket), then I would recommend the RCD lift.
  3. Nov 11, 2010 at 10:58 AM
    4cyltacoma
    Reagan
    Fresno, Ca
    Os the OME a better ride?
  4. Nov 11, 2010 at 11:14 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I don't believe ANY lift meets this criteria. They all have a higher spring rate than stock.
    Some folks will tell you that their truck rides "better" than stock, but these are probably folks that like a "firm" ride, or are loading their trucks so heavily that the stock springs are hitting the bumpstops.
    EDIT: especially since you're running a 4cyl - your truck is lighter than the V6s that lift designers were test fitting when they created their suspension kits.
