pro comp resevoir shocks
Discussion in 'Suspension' started by markmatters, Mar 14, 2012.
  1. Mar 14, 2012 at 12:37 PM
    markmatters
    markmatters [OP] Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    HTML:
    Found these on craigslist:
    http://yuma.craigslist.org/pts/2900137094.html
    For a good price...hes about to send me the extended and collapsed numbers..
    2.0 with 10" travel...what do you guys think? Will they fit my 4" inch lift ass? Also, would need a conversion kit if they do fit..
  2. Mar 14, 2012 at 3:48 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
  3. Mar 14, 2012 at 3:56 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Extended length roughly 26" and collapsed roughly 16" with 10" travel...again, i want to use these with a 4 inch rear lift..also consider the conversion...is it possible? Its a very good deal..
  4. Mar 14, 2012 at 4:42 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Procomp shocks no bueno
  5. Mar 14, 2012 at 4:58 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Procomp > Stock
  6. Mar 14, 2012 at 4:59 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Right on...
  7. Mar 14, 2012 at 5:00 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    If my truck is going to ride rough in the rear, might as well look cool with some resevoirs...lol...
  8. Mar 14, 2012 at 5:02 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    You are going to need an adapter for the top, the stock set up uses a pin not a rod end style but those adapters are not hard to come by.
    other than that I see no problem with it
  9. Mar 14, 2012 at 5:08 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Yeah, thats why i wanted to know if those measurements were good including the 1" more for the adapter...they are pro comp mx2.0 part exp-4704....they might be too long?
  10. Mar 14, 2012 at 9:20 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Do you have blocks right now? If so, it prob wouldn't make a diff either way!
    Measure what your collapsed length would be. Measure the shock mount to mount and minus the distance from bump stop to frame! The adaptor adds closer to 1.5"!
  11. Mar 14, 2012 at 9:34 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    3 in leaf pack and a 1" block....only way to keep my bro-ness to a miminum...i wish i knew more about shocks...i see that the 4" 5100 with 10" travel are abt the same length extended and collapsed as these, but if the adapter is more like 1.5" then...im already confused..
  12. Mar 15, 2012 at 5:36 AM
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    I have the 4" 5100's with my Expo Leaf pack. Whatever DSM publishes as travel #'s for them are about perfect for the Expos. Ironically enough, the box is labeled for Tundras, which kind of makes me wonder about the valving, but they work perfectly and I trust DSM.
  13. Mar 15, 2012 at 6:11 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I say to give it a shot. My ideal rear shock numbers are about 16"/27" with my allpro pack. Since you have the lift blocks, then i could see the adapter length be off set by the block height.
    The issues that may need to be fixed are:
    rear brake lines will be too short
    Bump stop may be too short
  14. Mar 15, 2012 at 6:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Adding 1.5" takes away from the compression but moves the extension; meaning you might run the risk of the shock bottoming out. You can combat this with a taller bump stop (if it is even a factor).
  15. Mar 15, 2012 at 9:24 AM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    I have extended brake lines...got them when i installed the lear pack and 1" block...i have spindles, eibach and .85 5100s up front...i really needed tuat height in the rear...after searching the p/n extended length is 27.07" and collapsed 17.44"....
  16. Mar 15, 2012 at 1:48 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    17.44" collapsed is already too long. the setup wont work
  17. Mar 15, 2012 at 3:30 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Well, eek. Got them....anybody want them? For sale if they wont work...lol. plus if they were installed like the stocks, the resevoir would be on the bottom...hmmm....
  18. Mar 15, 2012 at 3:40 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Buy the conversion kit, Gordies might have it. Install with the resi part up.
    the shocks will work for city driving, but you will need longer bump stops so the shocks dont compress before the bump hits.
    you will lose uptravel though
  19. Mar 15, 2012 at 4:14 PM
    markmatters
    Mark
    Yuma, AZ
    2007 PreRunner
    Not a gordies fan lol. My neighbor can fab it up for me..but can the rod be facing down?
  20. Mar 15, 2012 at 4:21 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I've never gone to gordies myself, i normaly just order stuff online.
    But yes, the rod can face down.
