Pro Comp Rims Beware
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redfishcatcher15, Dec 22, 2015.
  1. Dec 22, 2015 at 8:17 AM
    Redfishcatcher15
    Redfishcatcher15 [OP] Well-Known Member
    2016 Sky Silver Tacoma Double Cab SR5 RWD
    If people want to spend the extra dollars in labor and parts in replacing the studs with longer ones so be it. My preference I can live with it and I just making people aware of the issue with some rim combos with the new Tacoma. If they have the luxury of a rim shop closed to them, which I don't pre-fit to see.
  2. Dec 22, 2015 at 8:24 AM
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    The rim is not seated properly due to the center bore being too small. The center bore will need to be enlarged. Longer studs will not fix his issue.
    CanadaToy likes this.
  3. Dec 22, 2015 at 8:27 AM
    grichg
    grichg Well-Known Member
    rich
    Laguna Beach
    11 Tacoma 4x4
    Camburg 3.0 Coilovers Camburg A-arms All Pro rear bumper CBI Front Bumper LED Light Bar and PODs and some other misc
    I hear you. Good to give a "heads up"!
  4. Dec 22, 2015 at 8:28 AM
    Redfishcatcher15
    Like I'd said don't care in the reference to put extended treads on. Besides the problems is not with the lug nut length, its the stud length.
  5. Dec 22, 2015 at 8:31 AM
    Codydog
    Codydog Member
    '14 Tundra
    I don't think longer studs is the solution...aren't you essentially smashing the center cap against the drum ? If thats the case, you are relying on the plastic center cap to hold up and and keep everything tight and balanced...it's a flaw and longer lugs won't fix it !! IMO
  6. Dec 22, 2015 at 9:19 AM
    Redfishcatcher15
    Codydog,
    Your right, that is why I told the tire place to not install them or replace my studs. Go figures a tire place could figure that out or thought I was a dummy. Wrong been working on vehicle all my life since I was a 12 in my dad's shop.
  7. Dec 22, 2015 at 9:27 AM
    Redfishcatcher15
  8. Dec 22, 2015 at 10:22 AM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Hmmm, but all the haters said its the same truck as a GEN 2. Just slightly different skins.
  9. Dec 22, 2015 at 10:28 AM
    Redfishcatcher15
    Seeing reviews on the same Pro Comp rim that they are having the same problem with the Gen 2 to.
  10. Dec 22, 2015 at 10:31 AM
    Sam B
    Samuel
    Poway, Ca.
    none
    Thanks for the update Red!
  11. Dec 22, 2015 at 10:31 AM
    Redfishcatcher15
    Welcome Sam B
  12. Dec 22, 2015 at 10:40 AM
    Stu488
    Stu488 Well-Known Member
    Scott
    Parker, CO
    2016 Quicksand Tacoma TRD OR DCSB 4x4
    TRD Pro 17' with 265/70/17 BFG KO2, blacked out grill and emblems, Toytec Boss 2.0 kit w/aal, relentless fabrication 8" bed bars, Insain fabrication front bumper with Warn M8000S winch, Factor 55 flat link, cmc, RCI metal works front and control arm skids, bottle opener.
    Hmmm....5001 series with et lug nuts and no issues.
    Redfishcatcher15[OP] likes this.
  13. Dec 22, 2015 at 10:43 AM
    Redfishcatcher15
    Stu488,
    Did you have to change out the studs? Because that is what the tire place said or did you put longer lug nuts if so you proved me wrong and were only human! Which brand lug nuts did you go with? Pro Comp has the short ones that I have on and the longer ones to.
  14. Dec 22, 2015 at 12:50 PM
    Stu488
    Scott
    Parker, CO
    Stock studs. The ET lugs nut are from discount tire. As mentioned above, I did have to work the center cap onto the hub to make it work. Wheels are coming off tonight for the first time to do a lift. I'll update more after that, including pics of lug nuts used.
  15. Dec 22, 2015 at 1:16 PM
    #35
    Redfishcatcher15
    Watt maker,
    Finally someone knows what there talking about. Thank you for the valuable information. I'll purchase some ET lug tomorrow and try.
  16. Dec 22, 2015 at 1:24 PM
    #36
    TacoMafia
    TacoMafia 2002 Tacoma 4x4 / 2021 Tundra
    Chucky
    New Mexico, USA
    1st Gen Tacoma
    I have to ask what are ET lugs?
  17. Dec 22, 2015 at 1:32 PM
    #37
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yeah, suggested them earlier
  18. Dec 22, 2015 at 1:34 PM
    #38
    Redfishcatcher15
    I might missed your post, but thanks.
  19. Dec 22, 2015 at 2:37 PM
    #39
    pino
    pino Well-Known Member
    I'm astonished by how widely accepted garbage wheels are in the truck community. They're usually all black like that, bedazzled with chrome fake bolts around the lip or star patterns in the middle. No other automotive community has embraced such hideous and poorly made wheels as much as truck-people. People think they look mean and military-esque, but in reality they're just poorly built pieces of fake man-jewelry. Stick to something like FN wheels, or Level 8, or TRD. I can't wait for this trend to die, but it's proving to be a slow and miserable passing.
  20. Dec 22, 2015 at 2:45 PM
    #40
    Redfishcatcher15
    Pino,
    When you start forking out your well laced pockets with greenbacks to us budget minded people then I and others can afford those high dollar rims that did not cost that much to manufacture!!!!!
    Toynado likes this.
