Pro Comp Suspension Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Triggeradict, Jul 6, 2017.
  1. Jul 6, 2017 at 9:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    :facepalm:
  2. Jul 6, 2017 at 9:51 AM
    Triggeradict
    Triggeradict [OP] Active Member
    2013 Tacoma Off Road
    4 inch procomp lift Banks Monster Exhaust Volant CAI LED conversion
    They said no other coil would work and to put the oem back in WTF :( i dont have the cash to be wasting this sucks
  3. Jul 6, 2017 at 10:24 AM
    Triggeradict
    My question is if i find like bilstein 5100 coilovers or icon 2.5 that give me that 2.5-3 inch lift on the front can i just take out the procomp strut and coil spring out and replace just that part of the lift?
  4. Jul 6, 2017 at 10:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not following. That is 'the lift' isn't it? Or are there spacers too?
    The shock is not creating the rough ride. The spring is.
  5. Jul 6, 2017 at 10:45 AM
    Triggeradict
    Yah the spring is caused it over rated in the weight dept, so im saying can i just take the procomp strut and coil spring so everything in the front i installed and replace that with just a better coil over? or is pro comp bullshitting and i can just buy a better rated spring?
  6. Jul 6, 2017 at 10:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'm not in a position to really answer that.
    Worth your time to call Headstrong and Wheelers for some discussion.
  7. Jul 6, 2017 at 10:56 AM
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    I had this lift kit, wife got it for me, it rides super rough but it does soften a bit after a while. Swapped the rear to some OME shocks and Dakars.... Big improvement... Can't wait to do the front.
  8. Jul 6, 2017 at 10:56 AM
    bigdood
    bigdood Well-Known Member
    Yup.
  9. Jul 6, 2017 at 10:57 AM
    Triggeradict
    @Taco1999 what are you going to replace the front with ?
  10. Jul 6, 2017 at 10:59 AM
    Taco1999
    Jeremy
    Slidell, Louisiana
    I want to go with some kings all around eventually. I may go with some OME in the near term.
  11. Jul 6, 2017 at 11:01 AM
    Triggeradict
    @Taco1999 coilovers or just the strut and spring combo? can you send me a link sorry just curious
  12. Jul 6, 2017 at 11:05 AM
    Taco1999
    Jeremy
    Slidell, Louisiana
    OME is a shock and spring setup, I think they have different spring rates and a few different shocks to choose from. The kings are an adjustable coil over. You should heck out headstrong offroad. They are pretty knowledgeable and have good selection, prices and free shipping. I got my rear setup from them.
  13. Jul 6, 2017 at 11:14 AM
    Taco1999
    Jeremy
    Slidell, Louisiana
    What other parts are you referring to? The coil spring and shock is the lift. What else did you change up front?
  14. Jul 6, 2017 at 11:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Just to be helpful.
    The shock and spring are already coilover. Even when stock. I think the term you might be looking for is adjustable coilover.
    We don't have struts, we have shocks all the way around. Yes, the term is loosely used interchangeably, but they are not the same thing.
    You might find rereading post 9 to be helpful too.
    Good luck with your quest. As you started off saying, research is good!
  15. Jul 6, 2017 at 11:16 AM
    #35
    Triggeradict
    @Taco1999 did it put your stock UCA's at a etreme angle?
  16. Jul 6, 2017 at 11:18 AM
    #36
    Triggeradict
    yah crap sorry i keep mixing those 2 up so i have that kit and i have uni ball rough country UCA's because when i installed that lift kit it put my stock UCA'S at a extreme angle witch look really weird..
  17. Jul 6, 2017 at 12:49 PM
    #37
    Taco1999
    Jeremy
    Slidell, Louisiana
    You should be able to use those UCA's with any coil over or spring/shock combo
  18. Jul 6, 2017 at 12:51 PM
    #38
    Triggeradict
    they were a bitch to get on because of the size of that spring and how much tension it was under
  19. Jul 6, 2017 at 2:22 PM
    #39
    Taco1999
    Jeremy
    Slidell, Louisiana
    I have the same procomp up front and it only toke my like 20 minutes for each side to get my JBA UCA's on. The only thing that gave me any trouble was getting the long bolt out past the fender on the passenger side, the metal was a little harder to bend out of the way. What was giving you so much trouble?
  20. Jul 6, 2017 at 4:44 PM
    #40
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @Clearwater Bill I appreciate it.
    We will do what we can ;)
    #40
