Pro Comp UCA vs Total Chaos UCA
Discussion in 'Suspension' started by Low Range Off-Road, Jan 13, 2016.
  1. Jan 13, 2016 at 10:31 AM
    Low Range Off-Road
    Low Range Off-Road [OP] Well-Known Member
    Pro Comp
    Hey Guys, I have been wondering about these Pro Comp Upper Control Arms for a While now. Pro Comp is known for Manufacturing "Bro Truck" Style Lifts. Well Pro Comp has been Changing its pace for the past couple of years. They see that Customers don't just want a Lift that changes your looks. Individuals want a lift that can perform. With this as their new Engineering for front Pro-Comp has come out with some game changing products. So I decided to do some research and find out more on their UCA's.
    This product shouldn't be looked over. Their New Upper Control arms are something that grabbed our attention.
    These Control Arms are Made of Chromoly. And Not only that if you look at the finer Details this is not just Mig Welded. These Control arms are TIG Welded. This is the kind of Craftsmanship that you see on Trophy Trucks.
    They come with Grease Zerk Fittings for Easy Servicing and Zink Hardware.
    Now after Talking with one of the Main Managers with Pro Comp Manufacturing at SEMA, he brought out that the Joints in the Arms are an actual 1.00" FK Joint. Now to back it up Pro Comp also provides a nice Billet cap to cover your investment. He also added that these are Made in California and are made on a Laser Tub Cutting CNC. They then Powder Coat them Black.
    With every Pro-Comp Lift they offer their 60,000 mile 5 Year Warranty
    Pro Comp Part Number
    • 57002B - 2005-2015 Toyota Tacoma | 2003-2009 4Runner | 2007-2009 FJ Cruiser
    Oh and did we mention that they are the cheapest Uniball Upper Control Arm on the Market.
    Total Chaos
    Total Chaos certainly has a name. We have many orders for this high quality product. They have been at it for quite some time. We find that sometimes the name is, well just a name. Name dropping when your with your buddy's on the trail is sometimes a status. Saying you have Total Chaos is one of those company's that makes your buddy's Jealous. But we found that Total Chaos Upper control arms have nothing more than other company's out there.
    Total Chaos we all know is high quality. So its no surprise when we here that their components are Chromoly, standard with FK Uniballs and have added caster for better alignment. Total Chaos also has a history and many members have installed this product on their trucks and it is proven. Here are the specs below to look over.
    • 4130 chromoly tubular upper control arms are 100% bolt on and hand crafted in the U.S.A.
    • UCA's are designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed.
    • CNC machined tapered spindle adapters convert the factory ball joint to a 1" uniball for added component strength & maximum wheel travel.
    • TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
    • Custom profile upper and lower hi-misalignment spacers maximize droop wheel travel and are machined from heat treated 17-4 stainless steel.
    • Upper control arms combined with extended length coil over shocks will allow for up to 1" of additional wheel travel.
    • Urethane bushings reduce bushing deflection compared to stock rubber bushings.
    • Control arm pivots include zerk fittings to grease the urethane bushings & inner sleeves without disassembly.
    • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
    • Complete grade 8 hardware kit is included.
    Total Chaos Part Number
    • 96504 : 2005-2015 Toyota Tacoma | 2003-2015 4Runner | 2007-2014 FJ Cruiser Uniball Upper Control Arms
    The Conclusion
    The first and main difference is how the UCA attaches to the Knuckle/Spindle. Total Chaos uses a Grade 8 Bolt you can get at any hardware store with a machined tapered adapter. This is nice if you have a problem you don't have to find a custom part if you break this bolt. The bolt head is a standard head and a tool that you would have in your trail tool box vs the Pro Comp Star headed bolt that most of us don't even know what size it is might be difficult to track down. Total Chaos has the advantage in knowing that you could break and they make this already frustrating situation a little easier to handle.
    The second difference is that the Total Chaos arm is only Mig welded. Now don't get me wrong Mig is still proven time and time again and we all Mig weld in our garages but when we see a tig weld we all get a little happy inside and think Trophy Truck or Ultra 4. This is where the Pro Comp UCA has the advantage.
    The third is the price and warranty. The Pro Comp is priced lower and has a 5 year warranty. The Total Chaos has no warranty listed.
    You decide. Who's UCA's are the best Uniball UCA's for your buck?
    boostedka likes this.
  2. Jan 13, 2016 at 1:44 PM
    my27taco
    my27taco Member
    Bentley
    Utah
    2015 Tacoma dbbl cab SR5
    265/75r16 ko2
    While I tend to skip half of what is written and go straight to the peerretty pics, I have to say that Found myself reading, and actually contemplating what you have stated. I am planning on a simple 2-3inch and definately want to do it right.. Thank you for the details.
  3. Jan 13, 2016 at 1:47 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    prices? That looks like a hell of an arch on the Procomp
  4. Jan 13, 2016 at 2:00 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i cant really believe what im reading here..comparing ProComp to Total Chaos? wow.
    JDMjeremy, phx13 and Ice Horse like this.
  5. Jan 13, 2016 at 2:29 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Their*
  6. Jan 13, 2016 at 2:37 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Please discuss the advantages and disadvantages with respect to alignment for both. Specifically what can one expect as far as alignment numbers go when comparing the two; lets assume at a lift height of 2-3".
  7. Jan 13, 2016 at 3:17 PM
    nazepp1
    nazepp1 Member
    Nico
    Estero, FL
    2015 TRD Offroad Prerunner
    Removed mud flaps, flat black badging, Sportmans seat covers, Icon 2.5" RR ext travel coil-overs, Icon 2.5" RR rear shocks, Total Chaos UCA's, Icon AAL. FN Wheels BFD 18"x9", BFG KO2 285/65 R18.
    x2, TC > Pro Comp
  8. Jan 13, 2016 at 3:23 PM
    Fredfifty
    Fredfifty Back in a Mini
    Dave
    Big Island - SF Bay Area
    99 5 Lug V6
    DJM 3/4 DJM UCA BJ FLIP CALMAX SHOCKS POLYURETHANE SWAY BAR BUSHINGS POLYURETHANE UCA BUMPSTOPS ROLLED FENDERS DJM 4 INCH ANGLED BLOCKS (STEEL) MINI C-NOTCH FROM ROHDE FABRICATIONS MJBTACO LOWPRO BUMPSTOPS CALMAX SHOCKS ROLLED FENDERS
    Thanks for that read. I was thinking about going PC for my UCAs (moreso to keep it all PC)
  9. Jan 13, 2016 at 8:55 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    I know TC puts at least 500 race miles on their products before selling. Does Pro-Comp do anything similar? What material is the Pro-Comp uniball made from? I might have missed it skimming.
  10. Jan 14, 2016 at 1:33 PM
    Low Range Off-Road
    Alignment on both would be very similar. From what I understand is Total Chaos was one of the first to offer UCA's for the Tacoma. All other UCA's are most likely copy's or design's were influenced by the Total Chaos design. Total Chaos UCA's are "designed with added caster to aid in retaining factory alignment specs when aftermarket lift kits are installed. This reduces the darting or wandering in the vehicle's steering when 2.5"-3" lift kits are installed".
    I assume that Pro Comp has done the same. Pro Comp has always made Lifts for on Road use so they take alignment seriously because dealerships and 4 Wheel Parts across the country install them all the time and having customers come back because there wearing out tires to quickly is a real headache. Being that the Pro Comp's UCA's are made on a CNC Bender and Laser CNC each product would be with in spec.
    For the best alignment we always recommend SPC UCA's. With there fully adjustable Ball Joint it will away's align correctly.
  11. Jan 14, 2016 at 1:46 PM
    Low Range Off-Road
    Yeah Total Chaos beats there product up. Nothing is quite like Baja testing. Not sure with Pro Comp. I know they test with "FMVSS 126-Compliance Certification". And they are coming out with a Long Travel that they have been testing and they have gone past there release date because of redesigning the Control arms for better strength. So I assume they beat on there Kits as well.
    Pro Comp uses a FK uniball so the same as Total Chaos. My only my only question with Pro Comp is what thickness of material on the tube they use.
  12. Jan 14, 2016 at 1:48 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Pretty familiar with the whole alignment thing, I was just curious of real word results in order to provide a true side-by-side comparison. Specifically a comparison done by Low Range as Low Range is responsible for the thread. Since ProComp doesn't discuss this in the product description that I know of, real world results would be idea in order to point to PC UCAs as a true contender.
    Lets face it, you lift your truck and pay for these arms and you can't achieve ideal numbers, I don't see ProComp moving very many or these arms. As it is they will have a difficult time regardless of where they are made, overcoming the reputation for....... well lets just say so so quality product.
  13. Jan 14, 2016 at 1:49 PM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Price?
  14. Jan 14, 2016 at 1:51 PM
    Low Range Off-Road
    Hopefully you didn't take this as Pro Comp being better than Total Chaos. There is no way that Pro Comp can beat Total Chaos's Long Travel Kits and Baja Testing. I am only observing Pro Comp's Try at UCA's and they actually did a good job for what they have to work with. I was just bringing out that there UCA's is another possible choice out there. I was simply using a High Quality Product as a Comparison.
  15. Jan 14, 2016 at 1:51 PM
    Mr Salty
    Hermmy
    Lots of chrome
    I've seen them for around $500-600
  16. Jan 14, 2016 at 1:54 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Just so you know, I certainly don't.
    I think its great you posted this and for those who were not aware provides an additional option for UCAs.
    Justinlhc likes this.
  17. Jan 14, 2016 at 2:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm not trying to be an ass at all, but how are these any better than TC arms when they don't even offer a 1.25" uniball like Camburg does?
    Also, these arms run right around the same price TC does as far as I can see. Unless TC raised their prices to $1000 for UCA's.
  18. Jan 14, 2016 at 2:19 PM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    Subd for more info and possible test beds. I'm intrigued
  19. Jan 14, 2016 at 6:07 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    He's not saying anything is better than anything and camburg 1.25 arms weren't even mentioned.
    It's just a simple comparison between two VERY similar arms.
    The cheapest I've seen the PC arms is $599.
    Gunshot-6A likes this.
  20. Jan 14, 2016 at 6:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I think so. Are the TC arms really THAT much more? I haven't looked at the price of them on the simple count that I don't need them, but I can't see them being a lot?
    I was mentioning the Camburg arms simply because of Procomps design using the same sort of mounting style that Camburg does which doesn't have an upper misalignment, only a lower.
