Pro & Cons of T.S.B.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DocD, Mar 17, 2010.
  1. Mar 17, 2010 at 9:35 AM
    DocD
    DocD [OP] Well-Known Member
    Mn.
    09 access cab
    My dealership has agreed (without question) to change out the real leaf springs in my Tacoma, (and it sounded like this included new shocks?) and I was wondering if there is a down side to this service? as a rule I never go off road, about off road as I get is farm roads,unimproved roads (dirt) farm fields etc, but I do pull a trailer once in awhile and the first time pulling it with (1) MC in the trailer I did notice a pretty good sag, and this is what peaked my interest in getting this done, But after thinking about it I started to wonder, Is there a downside to this? Thanks, Doc
  2. Mar 17, 2010 at 9:46 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    None that I found. It's a truck and should do the things trucks do, like towing and hauling loads. A little stiffer suspension is the tradeoff if there is one.
    Edit - You would be wise to check their work after. Many have reported receiving the same 3 leaf springs after only having to do the work twice.
  3. Mar 17, 2010 at 9:48 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I agree, there is no downside unless the stiffer ride bothers you. Without the tsb 1@ bags of mulch make you sag, that shouldn't happen.
  4. Mar 17, 2010 at 10:08 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    3yrs later, all good.
    One downside, had adjust headlights up 2 clicks.:)
  5. Mar 17, 2010 at 10:14 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Harder ride? Sheesh. It still rides like a car. Not even as harsh as my '96 Tacoma was. Rode in a Ford F-350 the other day and almost lost all my fillings.
  6. Mar 17, 2010 at 11:09 AM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    i had mine done and love it. slightly stiffer but wont sag anymore like a little bitch s-10
  7. Mar 17, 2010 at 11:33 AM
    notquiteright110
    notquiteright110 Active Member
    knucklehead
    NE Texas
    07 taco DC 4x4 debadged
    black head lights, flowmaster exhuast, cheep beep mod, rear fog lamps, more to come when i find the money tree
    Man its worth it, the ride does differ a little, but you will be able to use the truck as it was intended to be used. I couldnt get off a smooth highway in mine before I had it done, and off-roading forget it. Had the swap, got a TRD suspension put on for free. I say go for it, make sure that if you have ever gone into the dealership with the complaint of the suspension, you keep that paper. I was way out of warranty, 75K, when I found out about the TSB on here. I called the dealership and after a long heated discussion and the proof I went in at 15K, they fixed it. No problems since then, well other than I want a lift, and cant decide which one...
  8. Mar 17, 2010 at 11:53 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Hi Folks,
    Someone here linked the TSB for this suspension fix. Upon review of the .pdf
    it stated my 09 (non-TRD) 4x4 doesn't require the change.
    Mine has 3 leafs and what look like a different shock?...Has this issue been fixed with better bump stops and the new shocks...
    the shocks are black, so i guess not Bilsteins?
    I've carried maybe 500lbs in the back without any noticeable sag?
    Havent had a trailer on it yet though?
    Thanks,
    Paul
  9. Mar 17, 2010 at 11:58 AM
    bb609
    bb609 O.F.
    NH
    The part numbers are stamped on each spring. Compare yours to the TSB but for sure, they're 3 leafs.
    OTOH, if you don't need them leave them be. LOTS of these trucks are being used with 3 leafs.
  10. Mar 17, 2010 at 12:03 PM
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I only noticed a slightly perceptible difference in the ride post-TSB. After the first drive, I couldn't tell anymore.
    I LOVE being able to use my truck as intended, towing with a load in a bed, without sag.
  11. Mar 17, 2010 at 12:33 PM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    No cons whatsoever in getting the rear spring TSB done. It still rides like a car compared to my old 2000 Tundra.
  12. Mar 17, 2010 at 1:19 PM
    Collins
    North Carolina
    Thanks BB,
    ...upon a reread of the TSB, it states do not replace the shocks
    or bump stops. So i guess that would mean to only replace/add the additional leaf?
    Funny, only my right side leafs PN's are mentioned on the TSB under
    the column OFP...what does OFP mean?
    In the description the TSB states:
    'Op code' -' Description'- 'OFP'
    SU7003 - RT Spring Assy. (Both Sides) - 48210-04550
    Thanks again.
  13. Mar 17, 2010 at 1:26 PM
    bb609
    bb609 O.F.
    NH
    I haven't read the updated one but unless your truck is TRD, you should get shocks too. TRD trucks just get springs as they already have the Bilsteins...unless it changed.
    OP code = Operation Code?
    OFP = NFC (no f*cking clue!):)
    Maybe someone else knows.
  14. Mar 17, 2010 at 2:14 PM
    MarineTacoDriver
    MarineTacoDriver Well-Known Member
    Brian
    Cherry Point
    09 SR5 4x4
    ARB front bumper, Warn M8000, ATO front/transmission/transfer case skids, Icon ext travel coilovers, Total Chaos UCA's, OME Dakar leaf springs, Bilstein/RCD 5100 3-4" lift shock, extended stainless brake lines, DrewFab shackle flip, rear ARB Airlocker, ARB air compressor
    09+ don't get the new shocks, our shocks are different from the base model shocks for 05-08
  15. Mar 17, 2010 at 2:34 PM
    Collins
    North Carolina
    Thanks for the input. I'll call my local dudes and see if they can clear this up for me.
    I'd like to be able to use the truck like a truck as you said.
    Maybe OFP means original factory part...??
    NFC for me too...haha.
    PC
  16. Mar 17, 2010 at 3:31 PM
    GT150
    GT150 Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    I have contacted 3 different dealers here in the Atlanta area, they all told me they would need to inspect it first. I guess I will need to load up some sand bags and waste a day for them to tell me "Ok"...........Don't understand why they need to look if they have a TSB on it.
    Wish I could find a "Fairy God Mother" dealership that would just tell me they would order the parts and call me when they come in.
  17. Mar 17, 2010 at 3:49 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    Don't you know anyone with a wood pile ?
  18. Mar 17, 2010 at 3:55 PM
    GT150
    Blairsville Ga
    2010 Prerunner V-6
    Wood would certainly weigh it down, I got some yesterday and hit the bump stops coming home. I think getting weighted bags of sand from Home Depot would be easier to prove how much weight is in the bed.
  19. Mar 17, 2010 at 4:01 PM
    FishErTaco
    FishErTaco Well-Known Member
    Chapel Hill, NC
    10 DoubleCab 4x4 SR5
    Extang Trifecta tonneau, black textured N-Fabs, AFE Pro Dry S, WeatherTech vent visors, WeatherTech floormats
    I got mine suspension TSB done a week ago. Don't notice much difference in the ride. I need to use it as a truck now and then, so definitely wanted to get it done. I had about 450# in it to test it and bottomed out over speed bumps in our neighborhood. Fortunately no problems getting dealer to do the work. Bed doesn't have as much spring now, can hold the weight fine.
  20. Mar 17, 2010 at 4:09 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Get em'. Mine were not really noticeably stiffer, but the truck looks better and handles loads better. I am very happy.
