Pro Grill or Factory?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Jan 9, 2021.
Which grill insert should I use?
  1. Keep what I have?
    47.8%
  2. TRD Pro Grill
    56.5%
Multiple votes are allowed.
  1. Jan 9, 2021 at 1:04 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I told myself I wasn't going to follow the masses and put a Pro grill on my truck, but the more I see these in person as well as in pictures online, I'm liking it more and more. Should I keep my grill I have on now, or swap it for the Pro grill? With the little tri-color emblem of course too.
    Xmplry808 likes this.
  2. Jan 9, 2021 at 1:06 PM
    TacoManOnBillies2015
    TacoManOnBillies2015 Member
    Blake
    2015 Gray Toyota Tacoma
    I like the grill on there now. Where did you get the tri color emblem?
    Island Cruiser likes this.
  3. Jan 9, 2021 at 1:06 PM
    scottstrong89
    scottstrong89 AhsokaTaco
    Carlsbad | CA
    2021 Tacoma SR5 2.7L DCSB Black (Sold 6-2-21)
    Bilstien 5100s- front 2.5inches Bilstien 5011s - rear extended HeadStrong OffRoad progressive AAL Manga flow muffler Aftermarket Powder-Coated Black Tip BFG KO2s- 265/70/17 Method Wheels Double Standard 17” Prinsu Cab Rack w/ Plano Rife Cases Yakima Awning Tacoma_Twins Paracord Handles TRD Pro Grille w/ Raptor Lights Laminx Fog Light Vinyl Yellow Me-So Customs Flip Fob Me-So Customs Gas Hole AJT Designs Emblem Overlay Black Me-So Customs Method Wheel Caps Screen ProTech 3 Piece Protector Kit Bumper Shells Bumper Caps Black tttacodan Bed Stiffeners TRD Pro Skid Plate TVD Vynil Decals Chrome Delete Hondo Garage Mounts w/ Ram Mounts RCI Adjustable 12” Bed Rack RotoPax Lox Mounts RotoPax WaterPax & Storage Pack Yakima Skyrise RTT WaterPort Shower Baja Born OffRoad Rock Sliders XBull Recovery Boards Al Off-road Trailgate Panel ataco4x4 Grille Emblem Desert Armor Ultra4 Ditch Light Pods Cali Raised LED 40” Light Bar Cali Raised OEM Style Switches
    I like your grille on the second gen way more than the second gen pro.
  4. Jan 9, 2021 at 1:07 PM
    Tacoma13_NC
  5. Jan 9, 2021 at 1:54 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Like what you have currently
    Tacoma13_NC[OP] likes this.
  6. Jan 9, 2021 at 2:05 PM
    gotoman1969
    Is that the white, light grey, dark great badge?
  7. Jan 9, 2021 at 2:07 PM
    Tacoma13_NC
    :thumbsup:
  8. Jan 9, 2021 at 2:17 PM
    Chief doc
    Chief doc Member
    2021 Trd Taco
    Eibach 2.0
    The stock grill looks great
    robm7 and Tacoma13_NC[OP] like this.
  9. Jan 9, 2021 at 2:18 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I too don’t like to follow the masses lol
  10. Jan 9, 2021 at 2:18 PM
    Chief doc
    Chief doc Member
    2021 Trd Taco
    Eibach 2.0
    What brakes did you use for the light bar
  11. Jan 9, 2021 at 2:19 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Stock grill was cool, but had to go. Love my “pro” grill. E247B86A-46B0-4FEC-95EA-2B779D3E6A36.jpg
  12. Jan 9, 2021 at 2:20 PM
    Tacoma13_NC
    Caliraised. It's a solid light and very bright.
  13. Jan 9, 2021 at 2:21 PM
    raguparm
    raguparm Well-Known Member
    2020 TRD OR DCSB MT
    I think the stock grill you have on there now looks better
  14. Jan 9, 2021 at 2:22 PM
    Tacoma13_NC
    Looks good. Don't get me wrong, I like mine already, but I always find myself changing things up too.
    Matmo215[QUOTED] likes this.
  15. Jan 9, 2021 at 2:23 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    I like the stock grill, I’ve just always liked the Toyota lettering more
  16. Jan 9, 2021 at 2:24 PM
    Tacoma13_NC
    I think the Pro grills look better on dark colored trucks like yours and mine. That's just my opinion though.
    Matmo215[QUOTED] and Xmplry808 like this.
  17. Jan 9, 2021 at 2:24 PM
    raguparm
    2020 TRD OR DCSB MT
    Just to add, I think the stock grill has the black “pro” feel but is more unique
    @Tacoma13_NC
  18. Jan 9, 2021 at 2:26 PM
    Black Bean Taco
    Black Bean Taco Well-Known Member
    2012 Tacoma Regular Cab
    265s, tint, head unit, sub, toolbox, LED light bar
    You don’t say lol mr.lowered
  19. Jan 9, 2021 at 2:43 PM
    Xmplry808
    Well i think here in Hawaii there are more Xrunners on this island then the rest of the states combined so to be different is hard to do.
    I personally like the shiny Toyota emblem, makes it more classy matches the headlights and my polished rims.
    To add some subtle but tasteful mod to the front, I cut the fins in the grill, mounted the required from plates on the side , yellow led fogs rather then just yellow lens. Also the more obvious added an oil cooler, and a tow hook to be unique. But later people will copy, as long as I was the first have it lol
    But like the op, I don’t like copying others. Maybe if there wasn’t as many trucks in my area with that same mod then maybe I’ll consider it.
    Another example is eyelids, black housing, retro fit headlights... ah I just keep mine stock lol7624107D-2FCF-452F-A9E7-195F92534D6C.jpg
  20. Jan 9, 2021 at 2:55 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    I put on the Pro grille back in 2015 when it was considered rare. Now with all the knock-offs and 95% of 3rd Gens with’em, I wanna change it back to the OEM lol.
