Pro Grill or Factory?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Jan 9, 2021.
Which grill insert should I use?
  1. Keep what I have?
    47.8%
  2. TRD Pro Grill
    56.5%
Multiple votes are allowed.
  1. Jan 9, 2021 at 3:26 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    That’s what I say, can never go wrong with keeping it stock cause people can’t talk (if it’s ugly, or copying others) it came with the truck lol, but hey at least you were one of the first ones to have it!
    To the op the trd pro grill does look good and nothing wrong with copying the masses it’s the way you want the truck to look and it’s YOU that’s gonna live with how you feel about the mod. Like you mention earlier the trd pro grill does match dark colors and is nice.
    That’s why I couldn’t vote it’s up to you lol
  2. Jan 10, 2021 at 7:07 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    I'm still on the fence about the grille insert, but I definitely want to color match paint the grille surround. The one I have now is plastidip'd which doesn't look bad, but I prefer the gloss painted version instead. I tried to paint it myself before and f'd it up, hence the reason it is plastidip'd now.
    TSSAustin likes this.
  3. Jan 10, 2021 at 11:58 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Which brand tricolor badge is that? The one you linked looks like white,grey, black. But yours looks like 3 colors of grey. Or is it just the picture.
  4. Jan 10, 2021 at 12:51 PM
    Tacoma13_NC
    It's more the picture. I'll admit it's a little washed out, I think the dark gray could be a little darker and the white could be a little whiter, but the picture makes it even worse than it is. It looks pretty cool in person.
  5. Jan 10, 2021 at 1:07 PM
    gotoman1969
    So it is the one you linked to Amazon?
  6. Jan 10, 2021 at 1:10 PM
    Tacoma13_NC
    Yes it is
    gotoman1969[QUOTED] likes this.
  7. Jan 10, 2021 at 1:14 PM
    Tacoma13_NC
    I ordered a new replacement OEM grill with the black color matched painted grille surround. I'm going to sell the current plastidip'd (aftermarket) grill and the original OEM grille (chrome surround) to offset the cost. I don't need three grilles. I'll just pop in the black T logo into the new one for now. I still may buy the Pro version insert too.
    Island Cruiser and Xmplry808 like this.
