Pro Grille + Raptor Lights Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by riverrat12, Oct 10, 2017.
  1. Feb 26, 2019 at 5:58 AM
    #61
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    Tullie D likes this.
  2. Mar 10, 2019 at 9:02 AM
    #62
    bigchrisz1
    bigchrisz1 Active Member
    2016 Tacoma 4x4 Sport
    Do your lights come on about five hours after you've shut off the truck and stay on for about 15 mins? I ran mine to EFI No 3 fuse because after using a multimeter I found that EFI powered up with the ignition. But I found that it turns the lights on for 15 mins four or five hours after shutting of the truck.
  3. Mar 10, 2019 at 10:06 AM
    #63
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    that happens sometimes but is a result the internal test built into the ECU....not an issue....however you could use the INJ 1 fuse it you like.....works the same way
    Denteen likes this.
  4. Mar 10, 2019 at 10:11 AM
    #64
    bigchrisz1
    Ok thanks for the reply!
  5. Mar 10, 2019 at 1:55 PM
    #65
    Og57
    Og57 Active Member
    Todd
    North Central Massachusetts
    2023 TRD-PRO Solar Octane
    Westcott TRD-PRO LIFT, 1.25” wheel spacers, 285/75-16 BFG KO2 on stock rims
    Looks awesome!
  6. Aug 12, 2019 at 4:34 PM
    #66
    lpfe42
    Kenny
    20 DCSB CEMENT
    5100/887 Icon uca
    Meso, Did you do a writeup on the wiring for the raptor
    to the drls ?
  7. Aug 12, 2019 at 5:12 PM
    #67
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sorry, had to laugh when I saw this.
  8. Aug 13, 2019 at 12:17 AM
    #68
    clayota
    clayota Well-Known Member
    San Francisco, CA
    2018 TRD Off-Road DCSB 4x4
    I wired mine into the cab to the taillight fuse. The raptor lights go on whenever my tails are on which is ideal for my needs. Visibility when I need it and stealth when I don’t
