Pro grille suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2k2, Oct 26, 2021.
  1. Oct 26, 2021 at 6:09 AM
    2k2
    2k2 [OP] Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
  2. Oct 26, 2021 at 6:21 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    I got mine in early 2019 from madhornets.com. There are innumerable threads on this here, concerning whether to use an official Toyota sensor cover or a knockoff. I have been using the one that I got with my TRD Pro grill from madhornets now, with no problems. Just as long as you alter the angle of the sensor to make up for the difference in height from the toyota symbol logo that comes on the truck and where the sensor is located a little lower in the TRD Pro grill, you will be fine. To do this, simply add a thin washer or two, behind the sensor to change this angle. This will work.
  3. Oct 26, 2021 at 6:38 AM
    239Taco
    239Taco Well-Known Member
    Austin
    SC
    2018 TRD Sport 4x4 white
    I just used empyreoffroad for a pro grille, good quality, very fast shipping. I’m happy with the purchase
  4. Oct 26, 2021 at 6:39 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I think all the grilles are practically the same. Its just the garnish that is a hit or miss on some grilles. I also bought mine on madhornets.com
  5. Oct 26, 2021 at 6:59 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Amazon, the reviews will guide you
  6. Oct 26, 2021 at 7:05 AM
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    same, but mine arrived cracked on one side. I just used gorilla glue and installed it.
  7. Oct 26, 2021 at 7:26 AM
    B1gDaddyT
    B1gDaddyT Well-Known Member
    2019 Cement Taco TRD OR 4x4 DCSB
    I always follow the reviews on Amazon. :bananadance:
    DAS Taco[QUOTED] likes this.
  8. Oct 26, 2021 at 7:32 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Keep in mind that if you have a front view camera your options are much more limited. I have it and the only one I've been able to find is the OEM all black grill.
    EL Taco Verde likes this.
  9. Oct 26, 2021 at 7:32 AM
    lalonguecarabine762
    lalonguecarabine762 Well-Known Member
    Brodey
    2022 F150 Tremor
    Previous 2016 TRD Offroad
    I went with the Cali Raised one which has been fine and I had no issues with the install. I know that brand has somewhat of a reputation for being cheap but the factory grills aren't exactly engineering masterpieces either. No matter who you go with, expect to trim a little bit of excess plastic from the molding process.
  10. Oct 26, 2021 at 7:46 AM
    MR.WaynesWorld
    MR.WaynesWorld Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    I too was faced with that same decision, Pro Grill, Raptor Grill etc... Being that mine had the TSS and front camera I really did not want to by a grill and then have to cut it to support the front camera, as with some of the grills I looked at.
    I ended up going with a OEM Nightshade Edition grill. No issues with TSS or Camera... Just trying to source a camera mount for it. But in the end was able to find one...
  11. Oct 26, 2021 at 7:53 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Not to hijack the OP's thread, but if I may ask whether you used an OEM or aftermarket TSS garnish, and where you found the front camera mount?
  12. Oct 26, 2021 at 8:01 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Used the same garnish that was on my Limited grill. Camera mount came from a TW member who 3D printed one.
    FL_TRD Sport[QUOTED] likes this.
  13. Oct 26, 2021 at 8:24 AM
    oogielaflick
    Keith
    This is a good point, as the earlier 3rd generation years did not come with a front mounted camera. I think this started with the 2020 models[?]. So yeah, in the case of those with front mounted cameras, your options are a little more limited. Good point...
  14. Oct 26, 2021 at 8:31 AM
    2k2
    2k2 [OP] Flareless
    Zak
    See Build Thread
    No front camera here. It's for an SR, so just TSS
  15. Oct 26, 2021 at 8:31 AM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    Does anyone make a correctly colored garnish yet? This is what stopped me from using an aftermarket garnish, the gray on them are terrible looking as far as shade of gray they use. I was able to find an OEM garnish that someone didn’t realize was worth $300 now on eBay for $50. Got the 2020+ pro grille from sparkparts for cheap using a VIN from a pro my dealer had for sale, lol.
  16. Oct 26, 2021 at 9:41 AM
    2k2
    2k2 [OP] Flareless
    Zak
    See Build Thread
    I'm just gonna go with the full taco garage setup. I've been researching for a couple days now and this is a gift for my son. I would like to know more about the TSS and the "washer" method to correct the angle.
    More important. Where do you add the washers?
  17. Oct 26, 2021 at 9:47 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    I kindly disagree. I personally believe Amazon’s review & rating system is so broken with fake reviews that it’s not really worth being used as a research tool anymore.
    $0.02 of opinion, of course. I think reviewing the forum here for member feedback would be a better bet for OP
  18. Oct 26, 2021 at 9:53 AM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Reviews help but I have no doubt they rig the system as well. Seems like every product now is "Amazon's choice" listed at the top... I think they put that on there to move stock, then switch it the next day after rebalancing inventory, just the impression I get, I have no data to back that up...
    As to the OP's question, aftermarket grills are NOT created equal. I went with taco garage when I bought mine on 2018, back then they were the best and closest OEM match. Mine has worked flawlessly the past two years with no issues at all with the TSS sensor. They'd be my "go-to" stop to check first, but things may have changed since then
  19. Oct 26, 2021 at 9:55 AM
    tacoman45
    Orygun
    Agree. I’ve noticed the same thing lately with Amazon’s recommendations. Reminds me of a Chinese flea market now. It’s actually kept me from buying shit from Amazon as often as I used to.
    dleithaus likes this.
  20. Oct 26, 2021 at 10:13 AM
    239Taco
    Austin
    SC
    That’s sucks, the only problem I had was they sent black Tacoma lettering, but they are mailing me the white ones and I get to keep the black so I’m not mad haha
