Pro on the interstate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by banjovol, Jul 12, 2020.
  1. Jul 12, 2020 at 2:42 PM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Correct but the lighter weight and gearing of the 2nd gens makes that difference so obvious. All I’m trying to tell the OP is that this isn’t a TRD sport vs pro issue this is a 2nd vs 3rd gen issue
  2. Jul 12, 2020 at 2:44 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Probably just a driver issue. Not much diiference in the engines. Toyota just went with 3.5L in a lot of vehicles.
    44-16 Taco likes this.
  3. Jul 12, 2020 at 2:47 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Nailed it. That’s about all there is to say on this...
    OP, try OVtune if you’re driving an automatic.
    Superdave1.0 likes this.
  4. Jul 12, 2020 at 2:49 PM
    banjovol
    banjovol [OP] New Member
    Stephen
    Tacoma Off road 09
    Thank y’all for the advice! It may well be the driver. I need to read up on what it means to tune it up and OVtune, Ned to do my homework.
  5. Jul 12, 2020 at 3:01 PM
    24-7
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    6MT. You will always be in the gear you want in the rev range you want.
  6. Jul 12, 2020 at 3:02 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    S-mode made the biggest difference for me. Set at 5th on the hwy. Much better throttle response.
    griffee, AKGSD and tcjacado like this.
  7. Jul 12, 2020 at 3:14 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Since we are talking about feelings - I can remember my dads old 25 year old Jeep Grand Cherokee and how that “felt” like it had a lot of power when in reality all they did it play with the throttle so it had a higher ratio of acceleration to peddle movement. I think I even recall Consumer Reports said something about it. I hated driving my dads Jeep on finicky dirt roads. Carefully try going over a rock and you got way too much RPMs and nearly jumped over the rock. If you design a truck for off-roading you want a lot of peddle travel to give you more control at slower speeds. You have the power but it’s further down the peddle distance.
  8. Jul 12, 2020 at 4:28 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    You are not the only one with regrets.
    https://www.tacomaworld.com/threads...lly-loaded-like-new-n-e-oh-37-900-obo.674269/
  9. Jul 12, 2020 at 4:35 PM
    SouthernFried
    SouthernFried Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    I doubt the Pro is gonna run much differently (if any) than the Sport or OR. Those trim levels are all very similar. The Pro will have all the bells and whistles, but the meat of the vehicle is essentially the same outside of the suspension and slightly larger tires.
    Chew likes this.
  10. Jul 12, 2020 at 4:53 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Ullie pics always rally the helpfuls!
    Superdave1.0[QUOTED] likes this.
  11. Jul 12, 2020 at 5:02 PM
    Truks4elk
    Truks4elk Well-Known Member
    3rd gen 4x4 OR crew LB
    I hear you on the change. I went from a 2010 to a 2020 (both TRD off road). To make things worse, I went from manual to auto. There sure feels like lots less low rpm torque in the new one, which seems to require strange transmission behaviors. I’m adjusting tho. No plans to replace it for at least 10 more years.
  12. Jul 12, 2020 at 5:25 PM
    griffee
    griffee Well-Known Member
    This. With the ECT button engaged.
