Pro Suspension on a OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastTx, Jan 12, 2018.
  1. Jan 12, 2018 at 8:09 AM
    EastTx
    EastTx [OP] Well-Known Member
    Texas
    2017 Super White DCSB TRD OffRoad 4x4
    i have read that some have bought the Pro suspension and put on a OR and it leveled it. Is this true? All the Pros that I have seen set about the same as a stock OR with front slightly lower. I know the performance will be better but will it set level?
    I have found a deal on some take off stuff is the reason I am considering this. If not I will go aftermarket.
    Can anyone chime in on this?
  2. Jan 12, 2018 at 10:17 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I actually saw a TRD Pro at my local dealership and did an unscientific test of the wheel gap using my phone as a rudimentary measuring tape. The height of my phone + case was basically the wheel gap of the Pro, maybe a smidge loose.
    My phone + case was basically the gap of my TRD OR, but maybe a smidge less loose than the Pro. I also am on stock size snow tires with about 9/32" of tread left. Based on this I'd venture to guess you might get 1/2 to 1/4" of lift with the Pro setup, if you're lucky. It's hardly the lift you'd get if you ran the Baja / Pro suspension on the 2G Off-Road.
    I was disappointed to see this myself, as I had thought about acquiring a take-off suspension at some point if someone was selling for a steal. If you're looking to level, here are other options (Bilstein 6112 / King come to mind).
  3. Jan 13, 2018 at 12:18 AM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    I installed TRD Pro Fox suspension on my 17 OR. The front sits one inch higher after the install but the rear remained the same. I posted this on another thread but can't remember the title of the thread.
  4. Jan 13, 2018 at 12:55 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    you need another tape measure, pro sits higher.
  5. Jan 13, 2018 at 9:13 AM
    EastTx
    Texas
    Nowhere did it say I measured it. That’s what I was asking for input. Why waste your time to comment on something if not going to be helpful. Appreciate it.
  6. Jan 13, 2018 at 9:47 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Post up your hub to fender, I'm curious where they sit. The one I did my quick and dirty measure was at most 1/2" higher than my OR based on tire to fender gap. Granted I was on snows, so I'm curious what it will actually sit. I honestly don't believe it's that much higher, definitely not 1" higher in stock form.
