Pro vs. Baja Suspension?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, Feb 20, 2015.
  1. Feb 20, 2015 at 6:13 PM
    littleblue81
    littleblue81 [OP] Well-Known Member
    Anyone drive both? Sounds like the PRO has different valving and spring rates, curious how it compares to the Baja.
    I have the Baja suspension and for the most part love it. You feel all the little bumps on the street but it's never painful...firm I would call it. But it helps a lot with street handling and it shines in the dirt when going fast, over relatively flat ground that has lots of undulations.
    Where it falls little short is bigger rocks, cracks, slow going over rocks, etc. Wondering if the Pro handles as well on the street or if there is a lot more induced body roll.
  2. Feb 22, 2015 at 8:03 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    I have a Pro and drove about 20 miles in a 14 Baja before getting the Pro. Front end is definitely more compliant in the Pro...mainly noticed it is less harsh on things like freeway expansion joints etc. Not much time in a Baja so not much too compare, though definitely better on the pro in my opinion. Then again, I notice a big difference running 35psi in the AT's where some folks on here see no difference between 35 or 45psi, so it is a matter of preference. Never had the Baja off road so can't speak to that.
  3. Feb 22, 2015 at 8:12 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Is it possible that the Baja had higher tire pressure than your Pro? The Baja and Pro both use Bilstien 5100s.
  4. Feb 22, 2015 at 8:54 PM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    They do not use 5100's, anywhere. Not even once.
  5. Feb 22, 2015 at 11:27 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    TRD Pro and Baja Bilstein suspension are way better than Bilstein 5100s.
    TRD Pro and Baja suspension are comparable to Bilstein 6112.
  6. Feb 23, 2015 at 7:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah im pretty darn sure the PRO has the same overpriced suspension as the baja.
  7. Feb 23, 2015 at 8:35 AM
    nd4spdbh
    SoCal
    lol YUP
  8. Feb 23, 2015 at 8:42 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    So do they use revalved 6112s or a unique shock only available from Toyota?
  9. Feb 23, 2015 at 9:23 AM
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    The 6112 is more like the re-valved aftermarket version. At least for the taco and tundra.
    The fronts in the Baja and Pro are the same body, slightly different valving between the two from what I understand.
    The rears are 5160 with specific valving for the Tacoma/4runner whatever its on. I am not sure if the taco and runner are the same.. Probably.
    Yes the shocks are a wear item and not covered under warranty. But the lift is factory and any problems caused with front diff etc etc Toyota can never say hey that's your lift's fault.
    The Baja setup is expensive but man I love it! Sure there are other options, but its all choices pick what you want!
  10. Feb 23, 2015 at 9:26 AM
    Konvict KROG
    Louisiana
    They sure can. But then you argue the advertising and stuff.
    Never a sure bet.
    Could get it cheaper, but you could get a fake hood scoop cheaper than the sport, or aftermarket wheels cheaper than the OEM wheels, or navigation cheaper than OEM etc etc.
