Proactive repairs
Discussion in 'New Members' started by Bert96, May 4, 2010.
  1. May 4, 2010 at 6:17 AM
    Bert96
    Bert96 [OP] Member
    NOVA
    3.4L 4x4
    Hello,
    I have a '96 tacoma extracab 4x4, with 3.4LV6. I'm about to hit 180K miles. I have a leaky valve gasket, been watching the oil level and it's slow to drop, but will have to be replaced. Just wondering if anyone recommends additional work to be done while the valve covers are off?
    I have always found this site to be a great resource, and look forward to your insite. Thanks.
    Bert
  2. May 4, 2010 at 6:31 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Replace your plugs, plug wires, and plug wire boots. My wifes 4Runner, which also had a leaking valve cover gasket just replaced, has 184K miles. When the mechanic was removing one of the plug wires one of them broke from being brittle. I'm sure yours should be replaced also. Also, your timing belt and water pump is do to be changed at 180k if it was replaced the first time at 90K.
  3. May 4, 2010 at 7:31 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    yup and ur pcv valve. if u keep up on ur maintence you should be ready for another 60k service... all the fluids, brake clean and adjust, driveline service, bla bla bla... ha
  4. May 4, 2010 at 7:34 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Sounds like you got some work on your hands..Good luck
    Welcome to TW
  5. May 4, 2010 at 8:57 AM
    Bert96
    Bert96 [OP] Member
    NOVA
    3.4L 4x4
    Thanks fellas
    timing belt at 65K and 135K, I'll douple check on the water pumps. driveline and Tranny service at 150K. new pvc valve 5k ago. I do need a new plugs/wires/boots. just wasn't sure about 2 birds/1 stone; opening up the engine.
    I'm not sure if the fuel filter was ever changed either. figure it couldn't hurt.
    Thanks for the help.
  6. May 4, 2010 at 9:00 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Well its good to know that your still keeping up with the maint. on the truck.;) Peoples vehicles break down and they wonder why?:confused:
  7. May 4, 2010 at 9:03 AM
    hillbillynwv
    Fairmont, WV
    Your suppose to change out the fuel filter every 30K but they can go at least 90K.
