probably a dumb question...but gear?
Discussion in 'Towing' started by 12tacoma928, Sep 22, 2012.
  1. Sep 22, 2012 at 6:02 PM
    12tacoma928
    12tacoma928 [OP] New Member
    plattsburgh,ny
    12 tacoma dbl cab
    I have a 2012 4x4 dbl cab automatic transmission with tow package, will be towing a 3620 dry hybrid travel trailer, have a weight distribution hitch which was included with the used camper. I have seen on the forum(s) people talk about "4" to keep the transmission in, but do they mean for a 5 speed manual or automatic? Should I be in "D" (think people on here have said that) or "4" for automatic?
    sorry to be such a noob! thanks for any help!:confused:
  2. Sep 22, 2012 at 6:07 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    D unless it is hunting , then 4
  3. Sep 22, 2012 at 6:08 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Automatics are the issue.....run them in 4th....not "D" when towing.
  4. Sep 22, 2012 at 6:09 PM
    OZ-T
    Peter North
    British Columbia
    Why
  5. Sep 22, 2012 at 6:12 PM
    Warputer
    2011 TRD Off Road
    Super Bro lift!
    Towing a load on the Interstate (55+ mph) with slight grades will have it shifting alot....overheating the fluid in the tranny....causing excess wear. In town or at lower speeds it would not matter.
  6. Sep 22, 2012 at 6:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Sep 22, 2012 at 6:17 PM
    OZ-T
    Peter North
    British Columbia
    That's what I said , D unless it's hunting , then 4
    Does the tranny cooler not cool the tranny fluid ?
  8. Sep 22, 2012 at 6:21 PM
    Warputer
    2011 TRD Off Road
    Super Bro lift!
    You are correct Oz.....you have to play it by ear when towing. I tow in "D" until I start hitting the hills. ;)
  9. Sep 22, 2012 at 6:21 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'd definitely install a seperate trans cooler to seperate it from the rad, considering the horror stories of the lines rupturing inside the rad then killing both the engine and the trans. [​IMG]
  10. Sep 22, 2012 at 6:27 PM
    OZ-T
    Peter North
    British Columbia
    Another one on top of the Tow Package cooler ?
  11. Sep 22, 2012 at 6:32 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If it runs through the rad then ya. I'd give it its own electric fan, too.
