Probably a horrible question with an obvious answer
Discussion in 'Wheels & Tires' started by Buckoma, Jan 31, 2018.
  1. Jan 31, 2018 at 6:38 PM
    Buckoma
    Buckoma [OP] Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I currently have 285/70/17 tires. The height/diameter is about perfect but I would like slightly skinnier width, maybe 1" less.
    Apparently no such tire exists? I've tried various combos (like 275/75/17) but discount and tire rack say there are no tires in the size I've selected. I've tried a couple other combos, same thing. I think the limiting factor is the 17" rim. Am I stuck with my current width?
  2. Jan 31, 2018 at 6:45 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    255/80R17 would be about the same OD and 30mm narrower(more than an inch)
  3. Jan 31, 2018 at 6:54 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Hmm, yeah that's probably about the closest... serious pizza cutters. I'll have to look at those someday in person. I'll probably end up with the same tire size as now (it's not that big a deal), but thought I'd see if anyone knew of a secret out there.
  4. Jan 31, 2018 at 7:22 PM
    Bannerman
    Johnson
    Charlotte, NC
    They work for me.
  5. Jan 31, 2018 at 7:26 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    A cursory search on that size shows limited options (mud terrains) and a higher price, being a little oddball I guess. I've got another ~15,000 miles to mull things over, but yeah I suspect I'll stick with the current one.
  6. Jan 31, 2018 at 7:30 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    I think 275/70r17 is the next “common” size. It is shorter than a 285. If you want the same height but narrower than 255/80 is the best choice.
  7. Jan 31, 2018 at 7:32 PM
    Cali007
    Cali007 Well-Known Member
    Jose
    Santa Rosa, Ca
    2012 DCLB
    Try looking at 34x10.50r17
