probably another dumb question
Discussion in 'Towing' started by bchdhs, Jul 6, 2018.
  1. Jul 6, 2018 at 9:32 AM
    bchdhs
    bchdhs [OP] New Member
    so bought a trailer with a hitch weight of 320lbs dry weight 2886 gvwr is 3635. i got the e2 weight distrubtion hitch with tounge weight 1000lbs rated for 10,000lbs is that to much of hitch for trailer i have?
  2. Jul 6, 2018 at 9:42 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Usually when things are “rated” it’s for the maximum capacity. In this case you’ll just be underutilizing what you paid for. You’ll know if the system is too overrated when you try to do the initial setup and you’ll see how many links you need to load up the bars. If you don’t mind sharing what make and model did you get? Also the weights you mentioned are dry I’m assuming?
  3. Jul 6, 2018 at 11:57 AM
    Rico's Taco '11
    Rico's Taco '11 Well-Known Member
    2011 Toyota Tacoma Double-Cab
    Class 3 Hitch and Trailer wiring harness
    There are calculators online to help you.
    Are you towing on the bumper or clasp 3 hitch on your frame?
    If you are bumper towing. Warning..
    If you have a class 3 hitch you will be fine. Just distribute your weight properly on the trailer. It should almost balance it self so you can lift it from the trailer tongue.
  4. Jul 6, 2018 at 1:12 PM
    bchdhs
    its a coachman clipper 17fq
  5. Jul 6, 2018 at 1:13 PM
    bchdhs
    n
    no i have factory tow package i believe its class V setup for 17 tacoma
  6. Jul 9, 2018 at 1:16 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    That is too heavy a WDH.
    When I was researching WDH for my truck I contacted the manufacturer of the Husky centreline hitch I was looking at. To be effective in BOTH weight distribution and sway they need to be loaded properly. Essentially you need a hitch that puts the actual weights in the middle of the range as best you can.
    That hitch will be outside of it’s range even if you are at the maximum of what your truck is capable of towing.
    Mtn Mike likes this.
