(probably) Stupid Fluid Film Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AgingDisgracefully, Jul 26, 2019.
  1. Jul 26, 2019 at 2:41 PM
    AgingDisgracefully
    AgingDisgracefully [OP] Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    So I am in rust busting mode on my frame and once I am done brushing off and painting I am hitting it with Fluid Film. This is probably a stupid question, but: my frame has the fine grime you'd expect after a year on the trails, even after hosing down. Further cleaning would be a royal pain. I assume it is OK to just spray with fluid film even with some grime on it?
    Thanks.
    GQ7227 likes this.
  2. Jul 26, 2019 at 3:25 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    I would scrub brush those areas with a bucket of hot water mixed with a liberal dose of Dawn liquid detergent soap, then rinse. But that's me.
    wahoobie likes this.
  3. Jul 26, 2019 at 3:28 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I agree with @MtnFisher
    Do your best to get it down to a clean frame then coat it. Tire brush to get the worst stuff.
    Biggest thing afterward is letting it adequately dry out prior to fluid film.
  4. Aug 30, 2019 at 5:01 AM
    do_ all_ball
    do_ all_ball Member
    2019 TRD Sport
    Fluid flim works better with dirt on the surface applied. It creates surface adhesion. Been doing this for years. Way better than any undercoat available. Just my 2 cents.
  5. Aug 30, 2019 at 5:11 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    5 years on this frame
    GQ7227, Skydvrr, do_ all_ball and 2 others like this.
  6. Aug 30, 2019 at 5:16 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    It’s an oil type substance, it will seep. Don’t stress about getting all the dirt off. In fact,when you redo it, you don’t want to get all the crap off as that will mean you washed off the left over fluid film.
    SIDELINER4 and GQ7227 like this.
  7. Aug 30, 2019 at 6:06 AM
    KVTaco
    KVTaco Well-Known Member
    The thing about Fluid Film is that it will collect junk but it's working. A pristine metal look means it isn't protected. I just spray and forget and if I spray it hard so it washes off, I reapply.
    SIDELINER4 and Spare Parts like this.
  8. Sep 7, 2019 at 9:56 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Digging up an old thread, do you guys attempt to clean the underside before re applying FF again?
  9. Sep 8, 2019 at 2:46 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I always go to a drive through car wash with under-spray a few days before re-applying each year. I also always re-apply in the early fall before it gets too cold. Don’t worry about getting 100% coverage when re-applying either; as other have said, FF creeps and moves around. It’s awesome stuff.
    IMO, the very first application of FF is when you want to do a good cleaning and get as close to 100% FF coverage as you can. I would never go as far as to scrub a frame with a brush, but a good pre-cleaning with a pressure washer in addition to a car wash has always worked for me.
  10. Sep 8, 2019 at 4:48 AM
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    Speaking of Fluid Film. Anyone know if there is going to be a Northeast Fluid Film gala this year ?
    SIDELINER4 likes this.
  11. Sep 27, 2019 at 8:43 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how do you mean redo it?
    a double application of this product is best?
  12. Sep 27, 2019 at 8:51 AM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    No, let the dirt on there and apply more. I’d rather have a greasy mess than rust
    GQ7227 likes this.
  13. Sep 27, 2019 at 9:59 AM
    AgingDisgracefully
    Peter
    I did try washing underneath, but no matter what there was always some dirt or fine grit here or there. For one thing each washing would liberate some more trail dirt that would seep down somewhere or spray somewhere as the water hit it. At some point I just applied it. So far so good.
  14. Sep 27, 2019 at 11:04 AM
    Spare Parts
    Southern Maine
    It’s recommended to do twice a year, at first. Then once a year. I have only done it twice and this will be my my 4th winter with the truck, my service advisor just told me my frame looks good.
    GQ7227[QUOTED] likes this.
