Problem.... advise needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nimbostratus, Aug 22, 2017.
  1. Aug 22, 2017 at 5:11 PM
    Nimbostratus
    Nimbostratus [OP] Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Guys I laid under my 08 DCLB today because I'm changing the suspension out tomorrow and was just looking around. I noticed some fluid dripping out of a boot then noticed caked nasty crap everywhere. I then noticed my power steering fluid is basically campletely empty. Here are some photos... I know it's hard to tell what your looking at. Thanks for the help guys.
    IMG_3253.jpg IMG_3254.jpg IMG_3255.jpg IMG_3256.jpg IMG_3257.jpg IMG_3258.jpg IMG_3260.jpg IMG_3261.jpg IMG_3263.jpg
  2. Aug 22, 2017 at 6:17 PM
    Nimbostratus
    Tuscaloosa, AL
  3. Aug 22, 2017 at 6:25 PM
    Muddinfun
    Muddinfun Well-Known Member
    Pressure wash the hell out of it, drive it for couple miles, then crawl underneath and look for where it's coming from.
  4. Aug 22, 2017 at 6:34 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Unless you can see it B4 cleaning things up, then all you can do is clean off all the gunk, refill the PS reservoir then take it for a drive and look around. Usually it'll be at a hose connection point, where the rubber hose meets the metal connectors. Unless of course there is a place where the rubber hose may be rubbing on something.
    If you can get a helper, crawl under the truck and have the helper turn the wheel back and forth, you might see where it's leaking that way.
    TRDSport10, scottalot and 98tacoma27 like this.
  5. Aug 22, 2017 at 6:49 PM
    Nimbostratus
    Tuscaloosa, AL
    So some dripping from the boot doesn't signify a specific issue? All the gunk is stressing me out. It's everywhere. Just didn't know if I should drop it off at Toyota or try to figure it out before they feed me some BS. Just didn't know also if it looked like that was the only issue.
  6. Aug 22, 2017 at 7:10 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Hard to tell from pics but if the source is from the boot on the rack you likely blew a seal on the rack. If you aren't sure I'd follow everyone's advise and clean the gunk to pinpoint the leak. If it is the rack you want to go with OEM only. Trust me. I sell auto parts. However, you don't want to replace a rack of you are leaking from the pressure hose or the pump. The gunk is road grime, etc for the most part sticking to the fluid. It's not like your steering system was loaded w/ chunks.
    TRDSport10 and GPsevinSixx like this.
  7. Aug 22, 2017 at 7:25 PM
    Nimbostratus
    Tuscaloosa, AL
    The last picture is the oil pan... why would there be gunk and fluid coming from it?
  8. Aug 22, 2017 at 7:25 PM
    Nimbostratus
    Tuscaloosa, AL
    Obviously if you can't tell already I'm a noob when it comes to this stuff.
  9. Aug 22, 2017 at 7:28 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Gravity and the leaking fluid wicking wherever it can go, then dust and grit sticking to it.
    lynyrd3 and 98tacoma27 like this.
  10. Aug 22, 2017 at 7:33 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    If you over grease your u joints or ever spill any oil and drive 5 miles it would look the same.
  11. Aug 22, 2017 at 7:55 PM
    Nimbostratus
    Tuscaloosa, AL
    Gotcha. Thanks brother.
  12. Aug 22, 2017 at 7:55 PM
    Nimbostratus
    Tuscaloosa, AL
    lol I'm obviously way too anal about this kind of stuff. Drives me crazy. Exspecially with my pretty new suspension going in tomorrow.
  13. Aug 23, 2017 at 12:39 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No actually if you were more anal about it you would crawl under and have a look every now and again. That has been leaking for a while.
  14. Aug 23, 2017 at 2:20 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    It won't be "pretty" for long. Why don't you fix the leak before changing out the suspension. Yeah, they're two separate and non related items, but I would clean up the fluid/dirt, identify/fix the leak, and then install the suspension.
    Jimmyh, TRDSport10, lynyrd3 and 4 others like this.
  15. Aug 23, 2017 at 3:07 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Well after that's installed I would bet you'll hear noises from time to time. Squeaking leafs, etc. it's the nature of the beast.
  16. Aug 23, 2017 at 3:36 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would be a lot more concerned about this than new suspension at this point.
    ABNFDC likes this.
  17. Aug 23, 2017 at 5:49 AM
    Nimbostratus
    Tuscaloosa, AL
    Just got the truck in the last few weeks. Thanks though.
  18. Aug 23, 2017 at 5:57 AM
    Nimbostratus
    Tuscaloosa, AL
    What's going to be my best course of action to clean up this mess? Degreaser and lay under the truck with a pressure washer? Im thinking I'm going to get the lift done and then drop it off at Toyota to get tires mounted/balanced, an alignment, and for them to check this issue out just to get it handled.
  19. Aug 23, 2017 at 5:59 AM
    Lester Lugnut
    Which means you didn't bother inspecting before you purchased. I'll bet that P/S reservoir was as dry 2 wks. ago as it is now. A lot of the gunky stuff you photographed is dry - meaning long-time build up.
    ABNFDC and scottalot like this.
  20. Aug 23, 2017 at 6:03 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Have the whole truck looked over by a trusted mechanic. You want to make sure there isn't more wrong with it.
    I agree with getting it all cleaned up and take it for a drive to see exactly where its leaking.
    Lester Lugnut likes this.
