PROBLEM AFTER ALIGNMENT
Discussion in 'Suspension' started by TheTacoma, Aug 2, 2016.
  1. Aug 3, 2016 at 7:08 AM
    Large
    Large Red
    155 ft lb for 2wd
    Also my alignment is good and my cam tabs are whack.. But it's still in spec
  2. Aug 3, 2016 at 7:10 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Front of front adjuster (Bolt Head), Rear of rear adjuster(Nut)
  3. Aug 3, 2016 at 7:18 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Is the piece I've been missing that the cams only work horizontally, not vertically?
  4. Aug 3, 2016 at 7:20 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Sounds like it. The cam sits in a Horizontal slot in the frame mounts. The bolt goes through the center of the control arm bushings. When the Cam(big offset circle) is vertical it has 0 effect on the control arm, when it is turned it pushes the control arm in towards the engine or out away from the engine.
  5. Aug 3, 2016 at 7:25 AM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    That makes more sense. Funny how things get set in your mind and it takes a dope slap to shake them out. I always thought they would also turn to adjust caster but now it makes sense why alignments can't put back caster. :frusty:
    IronPeak and TheTacoma[OP] like this.
  6. Aug 3, 2016 at 7:25 AM
    TheTacoma
    TheTacoma [OP] Well-Known Member
    Birmingham, AL
    2017 DCSB, TRD OR 4x4, Quicksand. SOS Bolt-on Sliders. 285x75r16. Kings
    Thank you! They came out and tightened it down in the parking lot where I work. He then took it back to the shop to put it back on the machine to make sure the alignment was still ok, since it had slipped.
    DaveInDenver likes this.
  7. Aug 3, 2016 at 7:42 AM
    Darklight
    Darklight Well-Known Member
    Bobby
    Charlotte,NC
    2008 Black SR5 V6 4Runner
    http://www.toyota120.com/forum/showthread.php?t=26920
    Thanks for the info!
    What they said,
    Glad to hear the shop is correcting the problem. I make sure every time i get an alignment that the tech torques them down properly.
    Bobby
    TheTacoma[OP] likes this.
  8. Aug 3, 2016 at 9:45 AM
    TheTacoma
    Birmingham, AL
    Got the truck back, now I will go check all the torques and give it a test drive on lunch. Thanks everyone for the information and help!
  9. Aug 3, 2016 at 1:16 PM
    TacoAlaMode
    TacoAlaMode Mr. Midlife Crisis
    Brian
    Huntsville AL
    10 DC LB MG 4X4 TRD Sport
    Icon Ext Coilover, Alcan Rear springs, Demello 3-Hoop Bumper and RockCrusher Sliders, Full tint 360', WeatherTech Floor liners and rainguards, Debadged, In Cabin 110 with 400w anytime, Diff breather mod
    And?
    So to further add content to this thread, maybe one of you guys can explain how they move the wheels forward in the wells. I would assume shorten the front, extended the back, correct the toe by adjusting the tie rods. My uppers (light racing) can adjust camber and castor.
  10. Aug 3, 2016 at 1:37 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    That's a little hard to understand but yes. You pull in the front adjuster and push out the lower adjuster to effectively point the LCA forward (positive Caster), and the opposite for pointing the LCA rearward (negative Caster). The Camber is changed with the same adjusters so that is why it's difficult/impossible to get alignment back in spec when you lift without new UCAs with added Caster/Camber built in or adjustments added to them.
    Because hot chick throwing sparks
    https://youtu.be/Ew87fLr6Omw
  11. Aug 3, 2016 at 2:53 PM
    TheTacoma
    Birmingham, AL
    Fixed the problem I was having! However, it almost seems like the "slam down" is back. I have a theory about this, the cam tab is still lower than before by about half an inch. I am wondering if that is lowering the LCA which is give the shock less travel inside on the way down and its now hitting the stop inside the shock again. I am very frustrated about this because it was riding so much better before the alignment and before it slipped after the alignment. I think I am going to take it BACK to the shop and see if I can get them to raise that cam tab back to the original position and align from there.
  12. Aug 3, 2016 at 3:06 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    The LCA cannot raise or lower by way of the adjuster cam.
  13. Feb 26, 2021 at 7:49 PM
    alxhrs
    alxhrs Member
    Had an alignment done after I put in some billies + aal. Right after the alignment lots of popping, creaking, etc. Thought it might settle out over time. I had specifically asked them to check all the main suspension bolts and torque them to factory settings since I had messed with it, they confirmed they did. I checked the LCA bolts, they were at around 20ft pounds torque, not 100 like they should be. Torqued them up and all the noises are gone.
    whatstcp likes this.
  14. Feb 26, 2021 at 9:07 PM
    SunsetDiesel
    SunsetDiesel Well-Known Member
    Hard to trust some shops these days.
