problem after getting lift and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 225nontypical, Apr 30, 2010.
  1. Apr 30, 2010 at 1:22 PM
    225nontypical
    225nontypical [OP] ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    a little background, i got my truck lift last week (tuff country 3" spacer and add a leaf on the back) then i went down and installed 285/70/17 tires on the truck ever since then, if i take a corner a little fast (not crazy and not any faster then i used to) the traction control starts to work, the truck beeps at me and i can feel the a weird vibe up front). so i did some searching on here and thought all i needed to do was take the truck in and get it re-calibrated. so i did that today and on the way back to work it did it again on an off-ramp!!!! it never did this until i got the lift and tires.
    the dealer told me it was my problem since i lifted the truck and that must be causing this.
    anyone have any other ideas why this might be happening??? again i just had the values rest to zero it out.
    thanks for the help.
  2. Apr 30, 2010 at 1:33 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    no issues on mine after lift and bigger tires, I would say its something else.
  3. Apr 30, 2010 at 1:37 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    could the front wheel speed sensors be damaged?
  4. Apr 30, 2010 at 1:38 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Now I'm not positive but this is the first I have heard of this issue.:cool:
  5. Apr 30, 2010 at 1:56 PM
    10.21 Well-Known Member
    Dillon
    North Carolina
    Black V6 Sport
    BHLM, Satoshi, Remove Mud Flaps, Debadge.
    Did you check the owner's manual? I was skimming through it awhile ago and I know they mention stuff about what could happen if you lift/modify the truck in anyway. I'm not completely positive though, but give it a look through, see if it mentions anything.
  6. Apr 30, 2010 at 2:01 PM
    225nontypical
    backwoods
    not sure i do not pretend to be a mechanic, so i would not even know where to look.
    i am wondering if it could have something to do with the tires themselves. i read a bunch of reviews on the duratracs (which is what i have, and i like so far) but a lot of reviews talked about weak side walls so if it were a side wall problem would that cause the sensor to go off????
  7. Apr 30, 2010 at 2:03 PM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    I've had this exact problem and we've had some lengthy discussions on it. This DOES have something to do with the yaw sensor being off a couple of degrees, thus kicking in VSC when it is not *truly* needed.
    I'll link back to the threads I have. Give me a sec.
  8. Apr 30, 2010 at 2:07 PM
    JDMcompliant
    Joe
    San Diego
    Here are the threads...
    This first thread is me freaking out about the issue, thinking it was a tranny issue. Later posts pin it down to a VSC issue.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/85637-2010-1-month-old-dclb-shot-transmission.html
    This thread is from another member on this site (OZ-T) who has had the same problem and gotten it fixed at the dealer. I will be taking it to the shop tomorrow with this information on hand.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/86826-sensitive-vsc-after-tsb-tranny-reflash-update.html
  9. Apr 30, 2010 at 2:11 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    I had the same problem after I installed my 2.5" lift. I called Toyota Corporate and asked how to recalibrate it or how to fix it and they refused to give instructions for anything that involves non-genuine toyota parts. I just lived with it.
  10. Apr 30, 2010 at 2:23 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  11. Apr 30, 2010 at 2:30 PM
    225nontypical
    backwoods
    i took it in they did that recalibration and it did not fix it. i did a search before i called Toyota and that i why i got them to fix it. so either they did it wrong or i have a different problem???? i trimmed the finders and mud flaps last week and that did nothing to help the problem so i think you are right there.
    it would be nice to figure this out since twice now it has almost made me hit another car!!!!!
  12. Apr 30, 2010 at 3:09 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    I still don't understand what a calibration would do. Like I said the nasty growl and beep kick on when I take incline corners at variable speeds. Hell it did it to me in a hospital parking lot just backing up out of a parking space after an alignment, so I stopped and noticed that the wheel was rubbing on the frame. It also looked like the technician messed with the wheel camber too much because the tire was slightly back.
    I will check with my dealer on the calibration, but I really dont understand why a lift would mess with it.
  13. Apr 30, 2010 at 3:12 PM
    JDMcompliant
    Joe
    San Diego
  14. Apr 30, 2010 at 3:25 PM
    BlueSteel
    James
    The Woodlands, TX
    Now that makes since. I will have to take it to the dealership I guess next week. Damn, and I fender trimmed a lot thinking that the tire was still rubbing on turns.
  15. Apr 30, 2010 at 5:10 PM
    HIKR
    HIKR Well-Known Member
    Tacoma, WA
    '09 4x4 dbl cab in pyrite mica
    6% Tint all around, Toyota all-weather floor mats, Toyota bed extender and skid plate, Python 991 remote-start alarm, oem cruise control and class III hitch were all installed within a couple months. I then installed Icon c/o's and Icon's 3-leaf aal with 17x9" GA9's and 285/70/17 Goodyear Duratrac's. The DRL mod was done, as was a custom rack setup similar to the org. cross bars. Blacked out headlights bought online, and a BOSS 1500 under-seat sub installed along with a Pioneer double-din DVD player
    I have the same problems, and I also have Duratrac's (like the OP). I am getting an alignment by the dealership here soon, and I am bringing in a copy of the VSC calibration pdf for them to do after the alignment. I have only had this issue arise on sharp, quick turns, and once on a wet off-camber turn (I don't think it should have kicked in even then). It's scary when it happens, and like some have said - VERY UNSAFE! It basically makes you understeer big time. Anyway, I will post back about how the alignment and VSC calibration affects anything. I don't like the idea of having to hold the VSC button for 3 seconds everytime I start the truck, but if that's what I have to do to be safer on the roads then so-be-it.
  16. Apr 30, 2010 at 5:17 PM
    SoCaliSnowboarder77
    SoCaliSnowboarder77 Well-Known Member
    Joe
    Valencia, Ca
    09 GSXR 600 & Snowboarders Hauler
    4x4 OFF-ROAD... that is all I need...
    Now I don't want to lift my Coma.
  17. Apr 30, 2010 at 6:22 PM
    225nontypical
    backwoods
    I went back to the dealer with paper work in hand they said they would do an alignment then zero it out again so we will see what that does but I have to wait until Wednesday but they said it would be free.
    when i took the paper work in with me they said that is exactly what they did today. but maybe another alignment will help
  18. May 2, 2010 at 1:04 AM
    JDMcompliant
    Joe
    San Diego
    Hey guys...I just went into the dealership today for my 5K service. I had them reset the VSC sensors to whatever it needed to be reset to, and things look really good. I took the truck on some pretty sharp turns at good speeds, and VSC didn't kick it.
    The dealer did mention to me though that that solution seems to be hit-or-miss...it solves the problem on some lifts and not others. Mine was lucky enough to be one that could be fixed with a reset.
    Cost me like $70 though, but whatever. At least the problem is gone. :p
  19. Nov 25, 2010 at 8:31 AM
    TPK555
    TPK555 Member
    Scott
    VA
    '10 double cab 4wd
    3' Lift on 32's
    What was the final verdict on the VSC issue with lift? Just got mine lifted and experienced the same problem. Will the alignment, YAW calibration, and reset the VSC resolve the issue? Agreed, it is a scary situation on the road!
  20. Nov 29, 2010 at 3:02 PM
    BlueSteel
    James
    The Woodlands, TX
    I did all of that and still have the same VSC issue, no guarantee. I might just upgrade to the RCS 4.5" lift in the future because I don't think the kit effects the VSC because of the drop bracket. I just learned to take corners slower.
