problem after installing 5100,s
Discussion in 'Suspension' started by longspur, Apr 28, 2012.
  1. Apr 28, 2012 at 5:17 PM
    longspur
    longspur [OP] Member
    Tim
    Ky.
    07 reg cab 4x4
    This is the first time that i've had a problem and couldnt search this forum and find the answer. I bought a 2007 reg cab 4x4 that a older man had, that had never seen a g with casterravel road much less mud. My problem is I just installed 5100,s up front set at 1.75 to level the truck up which it did, had it aligned at my normal shop, that i've been satisifed with in the past. The tires are 245-75-16 firestone destination,s that are 75% tread, after the alignment my front sounds like I have a flat spot on one or both of the front tires. They are wore some on the outside part of the tread, but not bad. My question is will the tires wear into the new alignment, and that is what is causing the noise or could it be the needle bearing that some folks have had problems with. I was hoping going 1.75 would not cause any problems with caster, sorry but I did'nt get a print out of my alinment.
    Thanks in advance for yalls help Tim
  2. Apr 28, 2012 at 5:20 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Are the rear tires worn the same? Maybe try a rotation to see what happens?
  3. Apr 28, 2012 at 5:24 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2010 TRD Sport DC LB 4x4
    Work in progress, but installed so far; 265/70/17 Duratracs, Spidertrax, OME885X coils with OME lean spacer, OME N140S and N182 shocks, Wheeler's 1.5" 3 Leaf Progressive AAL (kept the overload), LR UCAs. TP14 spacers
    IIRC improper caster doesn't usually affect tire wear
  4. Apr 28, 2012 at 5:24 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Alignment wise you should be fine at that setting! It's usually a good idea to get a print our or tell them where you want it. Does it drive good? I'd say its time for some me meats.....265's maybe?
  5. Apr 28, 2012 at 5:55 PM
    longspur
    Tim
    Ky.
    07 reg cab 4x4
    yea the back tires seem to be worn about the same as the fronts, I hate to get new tires when these have several more miles on them. I dont like them anyway, there a dang street tire. My main concern was that going 1.75 would not create any problems as in the noise and vibration. The truck drives great.
    Thanks
