problem changing the oil for first time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yv1650c, Jul 24, 2010.
  1. Jul 24, 2010 at 6:57 PM
    yv1650c
    yv1650c [OP] Active Member
    Carlos
    Venezuela
    I think it was going to be easy chaing the oil by myself, but the oil in the inverse oilfilter become on all parts, and now my engine is like an old truck engine lacking oil every part in the fornt left area.
    excuse my bad english, how do you do to not get oil in everywhere on the engine?
    thank you
  2. Jul 24, 2010 at 6:58 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    There should be a small hole there for the drainage. Hold something to catch the oil there and slowly take the oil filter off to reduce the spill.
  3. Jul 24, 2010 at 7:00 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
  4. Jul 24, 2010 at 7:00 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
  5. Jul 24, 2010 at 7:01 PM
    Tricky
    Tricky Well-Known Member
    Palmetto, Fl
    09 TRD Sport DC
    Anytime Fog Lights Bakflip HD Billstein 5100's Blacked Out Scoop Debadged FJ62 TOYOTA Smile Grillcraft Upper & Lower K&N Intake Magnaflow Cat-Back OEM Roof Rack Pioneer Speaker Upgrade Redline Hood Struts Slimcubby's HIDs Toytec 1.5 AAL
    A 32 ounce gatorade bottle was made for this.
  6. Jul 24, 2010 at 7:03 PM
    Brunes
    Brunes abides.
    Rotorhead
    I ran a piece of hose down to the frame. Coupla zip ties and it was a done deal. Testing it sometime this week.
  7. Jul 24, 2010 at 7:12 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    I use the the 3/8" (I believe) tubing attach it to the end under the filter and grey tape a 2 litre plastic bottle to the tubing on the exit end and catch the oil. Pour that in the recycle oil and take it all to autozone. No mess. 15 minute job.
    Azbackcountry
  8. Jul 24, 2010 at 7:14 PM
    SCFirefighter
    Stephan
    Cary, NC
    You keep it attached? I'd be afraid it would get too hot and melt
  9. Jul 25, 2010 at 6:09 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I would think that it would slowly drip oil for days?
  10. Jul 25, 2010 at 6:20 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Me, too. I use the 3/8' tubing but I remove it after each oil change. I have to store it in a plastic bag since it still has oil in it despite my best efforts to drain it all out... it would drip for at least a day if I let it.
  11. Jul 25, 2010 at 6:36 AM
    StarGazer
    StarGazer Well-Known Member
    MegaMan!
    Wherever, Tx.
    2007.5 Dodge Ram 2500 Mega Cab 4x4
    I've done so many mods to this truck it turned out to be a Dodge Ram 2500! WOW was that expensive!!
    I use 5/16" fuel line, I measured it to be long enough to reach my oil catch pan. But very rely do I need it because I drain the oil first then I remove the filter w/ the tubing attached for just in case.:)
