Problem! Help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrickTRD187, Feb 20, 2016.
  1. Feb 20, 2016 at 4:32 PM
    BrickTRD187
    BrickTRD187 [OP] New Member
    97 forest green Tacoma 4x4
    I have a 97 Tacoma 4x4 3.4 6 cyl. Not getting power to my fuel pump. I've replaced ecm , fuel pump,and efi relay. All fuses and relays are good not sure what else it could be. Please help me out.
  2. Feb 20, 2016 at 5:30 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Check your wires and grounds
  3. Feb 20, 2016 at 5:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    You have to start at the pump connection with a DVM and work back in the harness till you find where there is power. Once you find that, you know the bad component or wiring is between that point and the pump.
  4. Feb 20, 2016 at 5:40 PM
    BrickTRD187
    That's what I'm in the middle of right now. Thanks will post if I have success.
  5. Feb 20, 2016 at 5:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Be sure you have the key on.
  6. Feb 21, 2016 at 10:29 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    You may be aware of this but I will toss it out there.
    The fuel pump is not powered until the ECM sees the signal from the crankshaft position sensor (V6) or the cam position sensor on the 4 cyl. The crankshaft (V6) must be turning to generate the signal, just "key on" will not do it.
    Additionally, power for the pump goes thru both the EFI relay and the "circuit opening relay". They are in series and both must be functioning for the pump to come to life.
    Given what you have done up to this point and assuming the pump harness/connectors are good, the crank sensor harness/connector down by the pass side t-belt cover and/or the sensor itself could be the culprit along with the "COR".
    FWIW, Toyota implies that the ECM needs to see both the crank signal and the "STA" signal from the starter to allow fuel pump power. This is incorrect, only the crank signal is required.
  7. Feb 21, 2016 at 12:28 PM
    BrickTRD187
    That might be it. Haven't thought of the crank sensor. I'll check that out today and post if I have success. Checked all grounds and still in the process of tracking the harness back to the pump.
  8. Feb 21, 2016 at 1:40 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    "Circuit Opening Relay" location.
