Problem Installing 885 Springs Not Compressing
Discussion in 'Suspension' started by Drunknsloth, Feb 10, 2012.
  1. Feb 10, 2012 at 4:54 PM
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So I'm using this method here
    But I put in the 885 coils with the billys at 0" and the 885 doesn't compress enough for me to bolt the lower control arm back on to the hub assembly. Once the lower control arm is about 1/2" from where you bolt it to the hub assembly the Jack starts lifting the entire truck.
    Any tips?
  2. Feb 10, 2012 at 4:57 PM
    Drunknsloth
    Retribution
    South West
    Yeah, my truck is in pieces right now...
  3. Feb 10, 2012 at 5:00 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Pull the uca down.
  4. Feb 10, 2012 at 5:05 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    X2.
    If you haven't done it yet, pull the lines off of the UCA so it drops down lower. This may help.
    What type of spring compressor are you using?
  5. Feb 10, 2012 at 5:07 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Don't need to take the lines off the uca the way he is doing it.
  6. Feb 10, 2012 at 5:10 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Have a fatass sit in the cab while your jacking it up?
  7. Feb 10, 2012 at 5:12 PM
    Drunknsloth
    Retribution
    South West
    I'm considering it, do you think that it is just the weight problem? I saw your response on another thread using this method. What spring-shock combo do you have?
  8. Feb 10, 2012 at 5:13 PM
    Drunknsloth
    Retribution
    South West
    I'm not sure I know what lines you are talking about...
  9. Feb 10, 2012 at 5:15 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    I have 885's and 5100's. I have Camburg uca's, though. Not sure if that would make a difference when jacking it up.
  10. Feb 10, 2012 at 5:18 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Dude you don't need to do anything to the uca except push it down to close that gap you're talking about. It's easier when you have two people to do it this method. Did you even look at my write up in my build thread that I told you about in the last thread regarding this method you started awhile ago?
  11. Feb 10, 2012 at 5:21 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Nevermind. I watched his video that he's using.
    It doesn't matter. You are doing it a totally different way.
    I would just go rent a spring compressor from the auto parts store. Most likely your best bet at this point.
  12. Feb 10, 2012 at 5:21 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
  13. Feb 10, 2012 at 5:22 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    When the jack is raising the lca back up, you need to pull the uca down right before the point the jack starts to raise the truck.
  14. Feb 10, 2012 at 5:23 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  15. Feb 10, 2012 at 5:23 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Haha.
    At least I said sorry!
  16. Feb 10, 2012 at 5:24 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Put a jack under the LCA and jack it up into place.
  17. Feb 10, 2012 at 5:28 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    He is, but before it fully compresses the spring the last inch, it starts to jack the truck up, so he has to pull the uca down before it starts to jack the truck up to close theglastonbury inch of the gap so he can put the bolts in. That last part is a two man job, lining the holes up while someone puts the bolt in,
  18. Feb 10, 2012 at 5:28 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I believe he has tried that, but the coil wont compress enough.
    The issue is, the OME coils are longer that the eibach coils, so most don't realize that it will be harder to compress them.
  19. Feb 10, 2012 at 5:30 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    It's actually pretty easy. I have the same set up and had the same problem till we pulled the uca down.
  20. Feb 10, 2012 at 5:38 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Rent a normal spring compressor from Advanced Auto or Autozone and get it done. The method you're using never seemed like a good idea to me when dealing with stiffer lift coils. I know it's worked for some, but I'd rather compress the springs with a compressor or pay a shop to assemble the coilover.
