Problem installing readylift
Discussion in '5 Lug' started by Slysky13, May 1, 2018.
  1. May 1, 2018 at 4:23 PM
    Slysky13
    Slysky13 [OP] Member
    05 access cab tacom 5 lug
    Alright. I perched the readylift 2wd 5 lug Tacoma lift. I have followed the instructions on paper and the instructional video of the install. I have installed the shock spacer and was about to reassemble everything, But now when I try to place the upper control arm into the mounting point the shock makes contact. Anybody else have this problem and what do I do about. I’m a little frustrated because it’s supposed to be a bolt on kit. Any help would be great.
  2. May 1, 2018 at 4:26 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  3. May 11, 2018 at 7:33 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Did you turn it 180 degrees? I believe they leave that out in the instructions. But pictures are needed to see what you are dealing with.
  4. May 11, 2018 at 10:33 AM
    HOOVERxx91
    HOOVERxx91 New Member
    I had the same issue. I ended up rotating it into a different position. It cleared, but barely at full droop. With weight on it, it was fine.
  5. Jul 1, 2019 at 1:08 PM
    Ncklo7
    Ncklo7 New Member
    Nick
    Gray Tacoma Base
    I just installed a lift on my 5-lugger on Saturday and ran into the same issue. Hoping to get it straightened out tonight. I called the manufacturer of the lift kit and they said that the weight of the truck and an alignment will cause the upper and the strut to separate enough.
    wilcam47 likes this.
  6. Aug 9, 2019 at 10:08 AM
    JETACO13
    JETACO13 Member
    Jesse
    2013 Toyota Tacoma base access cab 2WD 4cyl
    100% stock
    Was the lift a success?
