Problem locating ADDW1 oil catch can on v6/6sp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacojpklx, Apr 5, 2014.
  1. Apr 5, 2014 at 11:57 AM
    tacojpklx
    tacojpklx [OP] Well-Known Member
    eric
    michigan
    '10 AC OR, Magnetic Gray, 6spd
    toytec lift (eibach, bilstein 5100 at 0, Recall springs +Sumo Springs) seat covers, tint, weathertecs, shrokwork sliders, brute force rear bumper, in bed hi lift.
    I bought the addw1 oil catch can on eBay after seeing that it worked out well for a lot of guys. I saw pics of it mounted on the driver fender well and it looked good. I looked at mine today and I can't mount mine there because the clutch reservoir is in the way. For the life of me I can't find a decent place on that side of the engine bay. Anybody have a solution? I'm not a fan of running all the way over to the passenger side....
  2. Apr 7, 2014 at 8:36 AM
    Count Macula
    Count Macula Active Member
    Moses
    Orange County, NY
    2011 TRD Off-Road
    Whats wrong with installing on the passenger side? Is it aesthetically displeasing?
    I mounted mine on the passenger side. I had mine on the driver side originally but access to the can was really tight so I moved it to the passenger side. The longer hose length will allow the warm air to cool more allowing you to catch more water and oil. No different than an oil/water separator on an air compressor, you catch less the closer your separator is to the source.
    Just make sure you either mount your can so the inlet is lower than the PCV valve or have no dips in your hose creating places where oil and water vapor can pool and potentially flow back towards the crankcase.
  3. Apr 7, 2014 at 8:38 AM
    82 yotaman
    82 yotaman H.O.G Hunter Of Gunman
    BUBBA
    Wyoming
    1982 toyta pickup/2013 toy MGM dcab 4x4 trd
    avs bugshield, avs inchannel vent visors, weather techs, trd shift knob, tailgate theft mod, windows tinted to 20%, wet okole front and back and black level 8 guardians wrapped in 265/75/R16 Duratracs oil catch can mod interior LED's, pop & lock pl5500, Leer 180 topper, OME full lift with Arb bullbar
    I installed my add w1 catch can and I have a 6 speed let me find the link I did a write up on it
  4. Apr 7, 2014 at 8:41 AM
    82 yotaman
    BUBBA
    Wyoming
    Go to the tread called OIL Catch Can look at post number 55 that is my pics of the install on a 6 speed hope this helps
  5. Apr 7, 2014 at 9:18 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I'm looking at this as well. Thanks 82 Yotaman.
    Just for options does anyone have pictures of how they mounted theirs on the passenger side?
  6. Apr 7, 2014 at 10:13 AM
    Count Macula
    Moses
    Orange County, NY
    2011 TRD Off-Road
    There are 2 holes on the passenger side you can mount up to, I used the one closest to the firewall. I fabbed up a mount from some angle. I don't have the addw1 can I made mine from an old air compressor oil/water separator.
    Best picture I have right now but you can get the gist...
  7. Apr 7, 2014 at 10:41 AM
    02Duck
    Thanks. I might try out this location. Is there any reason why the longer hoses would create a problem?
  8. Apr 7, 2014 at 3:12 PM
    tacojpklx
    eric
    michigan
    I will regroup and take a look at it again then. I just had it in my mind on the driver side aesthetically and bought the length of hose accordingly. I feel better knowing its been done on the other side. Glad to have the replies...it was about to be permanatly positioned in it's box on the garage shelf...
  9. Apr 16, 2014 at 8:20 AM
    02Duck
    82 yotaman, did you have to use a longer bolt than stock when you mounted the 1/8" flat under the fuse box bolt?
