Problem need help and or advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jdaniel1274, Jan 16, 2014.
  1. Jan 16, 2014 at 7:07 AM
    Jdaniel1274
    Jdaniel1274 [OP] Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    2001 Tacoma DC 4X4
    Was replacing brake light bulb. Bulb started smoking inside the bulb, now the brake lights, tail lights and dash lights do not work also it will not come out of Park with using the safety switch. Is the problem fuses, relays or switches?
  2. Jan 16, 2014 at 7:22 AM
    Jdaniel1274
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
  3. Jan 16, 2014 at 7:24 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    1st thing I would do is to check all your fuses. Start with the easiest fix first then move on.
  4. Jan 16, 2014 at 7:26 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    This, if nothing found check all the other bulbs see if they fried and shorted.
    Cypher
  5. Apr 30, 2014 at 9:24 AM
    Mtpeak
    Mtpeak Member
    Tampa
    05 Tacoma PreRunner SR5
    Same issue, except mine just went out randomly, did you find a fix?
